A Xbee Series 2 in Router AT configuration with a potentiometer wiper output connected to XBee's pin 20 AD0 is supposed to send the analog data every 100 ms. It was set with ATD02 and ATIR64.
A Xbee Series 2 in Coordinator API config is connected to the computer.
Using XCTU terminal, we can see that the Coordinator is constantly receiving Explicit RX Indicator frames from the Router. However there are no frames containing the analog data read by AD0 on the Router XBee.
Using Python with the XBee module, we also notice the same thing, just rx_explicit frames being received and nothing containing the analog data samples!
{'profile': '\xc1\x05', 'source_addr': '6T', 'dest_endpoint': '\xe8', 'rf_data': '\x01\x00\x00\x01\x02(', 'source_endpoint': '\xe8', 'options': '\x01', 'source_addr_long': '\x00\x13\xa2\x00@\xb1\x92\x13', 'cluster': '\x00\x92', 'id': 'rx_explicit'}
{'profile': '\xc1\x05', 'source_addr': '6T', 'dest_endpoint': '\xe8', 'rf_data': '\x01\x00\x00\x01\x02I', 'source_endpoint': '\xe8', 'options': '\x01', 'source_addr_long': '\x00\x13\xa2\x00@\xb1\x92\x13', 'cluster': '\x00\x92', 'id': 'rx_explicit'}
{'profile': '\xc1\x05', 'source_addr': '6T', 'dest_endpoint': '\xe8', 'rf_data': '\x01\x00\x00\x01\x01\xeb', 'source_endpoint': '\xe8', 'options': '\x01', 'source_addr_long': '\x00\x13\xa2\x00@\xb1\x92\x13', 'cluster': '\x00\x92', 'id': 'rx_explicit'}
{'profile': '\xc1\x05', 'source_addr': '6T', 'dest_endpoint': '\xe8', 'rf_data': '\x01\x00\x00\x01\x01\xce', 'source_endpoint': '\xe8', 'options': '\x01', 'source_addr_long': '\x00\x13\xa2\x00@\xb1\x92\x13', 'cluster': '\x00\x92', 'id': 'rx_explicit'}
What do you think may have happened? I checked the value at AD0 by reading it with an Arduino and indeed there is a value to be read.
  • \$\begingroup\$ Maybe you should provide a link that shows how connecting a pot to an ADC input will initiate data transmissions and not just sit there waiting for someone/something to instruct it to do just that. \$\endgroup\$
    Feb 22, 2014 at 12:15
  • \$\begingroup\$ @Andyaka I think if I set XBee to do at a fixed interval the reading from the ADC input pin and the transmitting of the read value, it should continuously transmit the data. The AT command used to do this was ATD0 2 to enable the ADC read and ATIR 64 to transmit every 100 ms. \$\endgroup\$
    – Nyxynyx
    Feb 22, 2014 at 17:03
Did you configure the AD0 pin as analog properly?
  • If you configured it properly, then it will send the IO sample frame.
  • If you did not connect anything to AD0 then it will send garbage value in the IO sample frame.
A router must have to be configured in API mode to use its analog pin.
See IO sampling using XBee for more information.
