Are these resistors in parallel? A question is asked to find the equivalent resistance between X1 and X2; to my knowledge, these resistors are like parallel connections. But the choices are given as:
- A. 2 Ohms
- B. 4 Ohms
- C. 8 Ohms
- D. 12 Ohms
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityAre these resistors in parallel? A question is asked to find the equivalent resistance between X1 and X2; to my knowledge, these resistors are like parallel connections. But the choices are given as:
is these resistors are in parallel ?
Hmm ...
Redraw the circuit so that it makes more sense is the main clue or even colour code all the nodes: -
Count the nodes. How many are there? Does this tell you how the resistors are connected? It should.
The right answer is 2 ohms. The equation can be found at parallel resistors
An instructor put this on test when I was a student, but not multiple choice, just pen and paper and slide rule. This was before calculators were invented.
