The voltage on capacitor is given by
$$V_c=\dfrac{1}{C} \int i(t)dt$$
and the current is
$$i(t)=0.4 \sin(2t-\frac{\pi}{4})u(t)$$
when u(t) is unit step function. May you show how to integrate the expression, how to find V, how to regard the step function while integrating?
  • \$\begingroup\$ consider using laplace to determine response to a step \$\endgroup\$ – JonRB Feb 23 '14 at 21:28
  • \$\begingroup\$ May you show how to integrate more or less step by step? \$\endgroup\$ – user40987 Feb 23 '14 at 21:32
    \$\begingroup\$ Consider: What does the step function look like from -infinity to 0? What does it look like from 0 to infinity? How can you use this to simplify the integrand? \$\endgroup\$ – Theran Feb 23 '14 at 21:40
First thing to note is that the step function is defined as
$$ u(t) = \left.\begin{cases} 0 & t<0\\ 1 & t>0\\ \end{cases}\right\} $$
so
$$ V_c = \frac{1}{C}\int_{-\infty}^{t_f} i(t) dt $$
$$ V_c = \frac{1}{C}\int_{-\infty}^{0} 0.4\sin (2t - \frac{\pi}{4} )u(t) dt + \frac{1}{C}\int_0^{t_f} 0.4\sin (2t - \frac{\pi}{4} )u(t) dt $$
$$ V_c = \frac{0.4}{C}\int_0^{t_f} \sin (2t - \frac{\pi}{4} ) dt $$
So all the step function does is set all values of t that are less than zero to zero.
You then continue to compute the integral in the normal way, so:
$$ V_c = \frac{0.4}{C} \left[ \frac{1}{2} \cos(2t - \frac{\pi}{4})\right]_0^{t_f} $$
| improve this answer | |
  • \$\begingroup\$ @ KillaKem Why does the integral need to be considered at first place from -infinity? Doesn't time starts at 0? \$\endgroup\$ – user40987 Feb 24 '14 at 3:28
  • \$\begingroup\$ Starting the integral at -infinity is the general case, it works if the function is zero for t < 0 and if the function is not zero for t < 0, that is why we start from -infinity.In your example because we know t is time we know the system is not defined for t < 0, so we can just start the integral at t=0 immediately.But the point of the function u(t) is to make it absolutely clear that the integral starts at t = 0, so anyone evaluating the integral knows they are working with a system that is zero or all values below 0 (this is called a causal system). \$\endgroup\$ – KillaKem Feb 24 '14 at 12:25
First, write your first equation more correctly as so
$$v_C(t) = \frac{1}{C}\int_{-\infty}^t i_C(\tau)\, d\tau $$
Now, because of the presence of the unit step we have
$$v_C(t) = \frac{1}{C}\int_{-\infty}^t 0.4 \sin(2\tau-\frac{\pi}{4})u(\tau)\, d\tau = \frac{1}{C}\int_0^t 0.4 \sin(2\tau-\frac{\pi}{4})\, d\tau$$
In other words, the unit step in the integrand has the effect of changing the lower limit of integration to \$\tau = 0\$.
The step function simply allows you to start integrating at \$t = 0\$ and know that \$V_c = 0,\ t \leq 0\$.
The integral itself should now be straightforwardly solved by using the primitive function and inner derivative.
