uC: EM357 datasheet
RS-485 IC: sp3078e datasheet
Two input pins on the sp3078e need to go high at the same time when I'm sending bytes. I'm using a single output pin on the EM357 to drive both of them high and low. The EM357 datasheet says the max output current for the pin that I'm using is 4 milli Amp. The max input current on the sp3078e is 1 micro Amp. Do these connections require any series resistance or pull-up/pull-down?
