To find clock frequency we need to find the minimum required time for data to pass from FF2 to FF4.
Here FF2 is the launching flop with clock CLKN. CLKN is the output of clock divider FF3. So CLKN = CLK/2. Since CLKN comes from a flipflop output, it will lag the the CLK signal by the propagation delay of that flipflop. This delay is 10.5ns.
FF4 is the capturing flop with clock CLK. So we have datapath with different launching & capturing clocks. Here is a simplified diagram:
and here is the timing diagram for this path:
tpd_FF3 is lag time between CLK an CLKN. The curved arrow shows the timing window for this path. In this path we will have additional propagation delay for FF2 marked as tpd_FF2. And of course the setup time for FF4, tsetup.
Now to operate this circuit correctly, we must have,
$$ T_{CLK}- t_{pd\_FF3} - t_{pd\_FF2} > t_{setup} $$
$$ T_{CLK} > t_{pd\_FF3} + t_{pd\_FF2} + t_{setup} $$
so, the Minimum value of T = 10.5 + 10.5 + 4.5 ns = 25.5ns and maximum frequency for CLK is 1/25.5ns = 39.2Mhz
If there is no deskewing flop FF4, CLKN signal will always lag with CLK signal. So you'll have a skew between launching & capturing clocks in the synchronous system. If you have other combinational elements in the datapath before going to the synchronous system, the path will have less time to be stable because of this skew. After adding the FF4 that additional skew in the clock path will be removed, because now both launching & capturing clocks are same.
