First off, it is a common practice that parameters are upper case. When reading code this helps identify constants from variables. For arrays, refer to IEEE Std 1800-2012 § 7.4 Packed and unpacked arrays.
- Packed means all the bits can be accessed at once or sliced
- Unpacked means each index must be individually selected.
The following have the same dimensions:
logic [N-1:0] arr_up [M-1:0];
is M unpacked arrays, each with N packed bits
logic arr_uu [M-1:0] [N-1:0];
is M unpacked arrays, each with N unpacked single bits arrays
logic [M-1:0] [N-1:0] arr_pp;
is M-by-N packed array, a slice of N-bits can be read out of the M index
Unpacked arrays can be initialized with a single digit: logic [N-1:0] arr_up [M];
is equivalent to logic [N-1:0] arr_up [0:M-1];
. Do note that the [M]
is [0:M-1]
not [M-1:0]
The differences is in the access. All can access a single bit, but only packed bits can access a slice.
arr_up[M-2] = {{N{1'b0}}}; // legal
arr_uu[M-2] = {{N{1'b0}}}; // illegal, assigning packed to unpacked
arr_pp[M-2] = {{N{1'b0}}}; //legal`
arr_up[M-1:M-4] = {{3*N{1'b1}}}; // illegal, unpacked cannot use sliced array
arr_uu[M-1:M-4] = {{3*N{1'b1}}}; // illegal, unpacked cannot use sliced array
arr_pp[M-1:M-4] = {{3*N{1'b1}}}; // legal
arr_up[M-2][N-5] = 1'b0; // legal
arr_uu[M-2][N-5] = 1'b0; // legal
arr_pp[M-2][N-5] = 1'b0; // legal
arr_up[M-2][N-5:4] = {{N-9{1'b1}}}; // legal
arr_uu[M-2][N-5:4] = {{N-9{1'b1}}}; // illegal, unpacked cannot use sliced array
arr_pp[M-2][N-5:4] = {{N-9{1'b1}}}; // legal
If the simulator is only accessing a single bit or index, unpacked arrays will give better performance. This is because packed arrays are accessed as a whole even if only one bit is being used. There is a balance between the simulators lookup overhead and number of lookup operations. Generally 2-D arrays are unpacked arrays of packed arrays. Adding dimensions is normal on the unpacked side. bytes, integers, words, and data buses are packed.
With typedef enum logic [N-1:0][1:0]{S0,S1,S2,S3} statetype;
, be aware this is creating the definition of the state type. It is create a 2*N-bit array but only allows 4 values.
For an array of 4-state state machines, I would recommend:
typedef enum logic [1:0]{S0,S1,S2,S3} state_et;
state_et state[N], nextstate[N];
