In a class I'm learning about dynamic energy and dynamic power and the notes seem to be incomplete.
• Dynamic energy
  Transistor switch from 0 -> 1 or 1 -> 0
 0.5x Capacitive load x Voltage2
• Dynamic power
 0.5x Capacitive load x Voltage2 x Switching Frequency
I've seen simillar formulas used in other places, for example I've seen other formulas that don't have 0.5 but require the value of a constant. Is 0.5 the average or something? Also what is switching frequency in the context of computer hardware? Is that the speed the CPU operates at (e.g. 2.5GHz)?
Energy in a capacitor = \$\dfrac{C\cdot V^2}{2}\$
That is the standard formula for the energy stored in a capacitor by virtue of it being charged to V volts.
If this energy is liberated (lost) into heat at f times per second then the power liberated is
\$\dfrac{f\cdot C\cdot V^2}{2}\$
Most of the energy lost due to "driving" capacitance will probably be from IO from the CPU such as driving the bus - although the frequency (f) will be much smaller than 2.5GHz (for example) the PCB track capacitance and input capacitance of bus chips will make this the dominant losses in a lot of cases.
Here's a good website that gives the derivation for energy: -
  • \$\begingroup\$ Big thanks! You mention the word "capacitor" and my notes use the word "transistor". What is the difference? \$\endgroup\$ – Celeritas Mar 6 '14 at 18:33
  • \$\begingroup\$ A mosfet is noted for it's large gate capacitance. Within a chip this will be a factor.Also in some memory devices mosfet capacitance is used as the storage element. The lower the parasitic capacitance the lower the power. \$\endgroup\$ – Andy aka Mar 6 '14 at 19:17
