Suppose we have a very simple circuit, with just a resistor between a wire connected to a power source. What's the actual value of current travelling the wire before and after the resistor? Is it different? Or is it the same across the wire, between the power source?
My guess is that it should be the same, since the resistor limits the current flow, thus create a "congestion" for the current that goes through it. This congestion also slows down the current before entering the resistor and lessen the overall electrons flow through the wire because the resistor is limiting the total amount of electrons that can pass the resistor. So even if the wire can carry more electrons, but the resistor is limiting it, the wire only supplies the amount of electrons allowed by the resistor and the amount of electrons actually on the wire are the same as the maximum go through the resistor. Is this correct?
