In the top-right of this panel, you can see two red and two white connectors. Can anyone help me identify what kind of Molex they are?
Device with connectors
Edit: Here is what the cable end of the connector looks like, ignore the extra piece of wire shorting some of the connections:
    \$\begingroup\$ Could we possibly get a close up? Along with a ruler for dimensions? \$\endgroup\$ Commented Mar 13, 2014 at 5:17
  • \$\begingroup\$ This is a picture I found online. I do however have one of these at home so I can snap a pic later on. \$\endgroup\$ Commented Mar 13, 2014 at 5:29
  • \$\begingroup\$ These look incredibly similar to the DC backup supply connectors used on certain Cisco networking gear. They're likely a standard type, but I don't know specifically. \$\endgroup\$
    – Polynomial
    Commented Mar 13, 2014 at 10:22
  • \$\begingroup\$ Are you sure they're made by Molex? Do you have a manufacurer's part number for the assembly? \$\endgroup\$
    – raaymaan
    Commented Mar 13, 2014 at 13:00
  • \$\begingroup\$ My guess would be the common post headers made by 3M, Amphenol, and many others. The most common size has 0.025" square pins on 0.1" centers, but there are also metric versions. They may be called "ribbon cable connectors". \$\endgroup\$ Commented Mar 13, 2014 at 16:26
I figured it out, they are JST XMR connectors.
Specifically XMR-10V and XMR-06V
