Checking uart overrun and framing error flags in linux. In some microcontrollers I can access overrun and framing error flags programmatically. Is it possible to access these flags from command line?
    \$\begingroup\$ What are you running Linux on? \$\endgroup\$ – Nick Alexeev Mar 14 '14 at 18:11
  • \$\begingroup\$ On Beaglebone Black. I can send ok, but receiving too many bytes. Other equipment works ok. with very same settings. \$\endgroup\$ – sdfsdfsdf Mar 15 '14 at 8:24
I've read and written to registers in the past by writing a kernel module that creates an entry in the /proc filesytem. Then I can read the registers by doing cat /proc/lpc32xx_regcheck for example.
This code might be garbage; It might be against "best practices" to do it this way. I'm not a Linux programmer by any means, but it worked for me for debugging.
#include <linux/init.h>
#include <linux/module.h>
#include <linux/device.h>
#include <linux/io.h>
#include <linux/kernel.h>
#include <linux/fs.h>
#include <linux/proc_fs.h>
#include <linux/fb.h>
#include <linux/stat.h>
#include <mach/platform.h>
#include <mach/hardware.h>
#include <mach/i2s.h>
struct proc_dir_entry *lpc32xx_regcheck = NULL;
static int my_proc_read(char *buf, char **start, off_t offset, int count, int *eof);
    int len = 0;
    len += sprintf( buf + len, "LPC3250 I2S REGISTER DUMP:\n");
    len += sprintf( buf + len, "I2S0 RXFIFO     :0x%X\n", __raw_readl(io_p2v(0x2009400C)));
    len += sprintf( buf + len, "I2S1 RXFIFO     :0x%X\n", __raw_readl(io_p2v(0x2009C00C)));
    len += sprintf( buf + len, "I2S0 STATE      :0x%X\n", __raw_readl(io_p2v(0x20094010)));
    len += sprintf( buf + len, "I2S1 STATE      :0x%X\n", __raw_readl(io_p2v(0x2009C010)));
    len += sprintf( buf + len, "I2S0 DMA0       :0x%X\n", __raw_readl(io_p2v(0x20094014)));
    len += sprintf( buf + len, "I2S1 DMA0       :0x%X\n", __raw_readl(io_p2v(0x2009C014)));
    len += sprintf( buf + len, "I2S0 DMA1       :0x%X\n", __raw_readl(io_p2v(0x20094018)));
    len += sprintf( buf + len, "I2S1 DMA1       :0x%X\n", __raw_readl(io_p2v(0x2009C018)));
    len += sprintf( buf + len, "I2S0 IRQ        :0x%X\n", __raw_readl(io_p2v(0x2009401C)));
    len += sprintf( buf + len, "I2S1 IRQ        :0x%X\n", __raw_readl(io_p2v(0x2009C01C)));
    len += sprintf( buf + len, "I2S0 TXRATE     :0x%X\n", __raw_readl(io_p2v(0x20094020)));
    len += sprintf( buf + len, "I2S1 TXRATE     :0x%X\n", __raw_readl(io_p2v(0x2009C020)));
    len += sprintf( buf + len, "I2S0 RXRATE     :0x%X\n", __raw_readl(io_p2v(0x20094024)));
    len += sprintf( buf + len, "I2S1 RXRATE     :0x%X\n", __raw_readl(io_p2v(0x2009C024)));
     len += sprintf( buf + len, "\nWriting to P_MUX_CLR...\n");
    __raw_writel(0x1c,io_p2v(0x40028104));
    len += sprintf( buf + len, "NEW P_MUX STATE :0x%X\n", __raw_readl(io_p2v(0x40028108)));
    if(len <= count + offset)
        *eof = 1;
    *start = buf + offset;
    len -= offset;
    if( len > count)
        len = count;
    if( len <0)
        len = 0;
    return len;
static int __init test_init(void)
    printk("Hello.\n");
    lpc32xx_regcheck = create_proc_entry("lpc32xx_regcheck", S_IRUSR|S_IWUSR|S_IRGRP|S_IROTH, NULL);
    if (lpc32xx_regcheck)
        lpc32xx_regcheck->read_proc = my_proc_read;
    return 0;
static void __exit test_exit(void)
    printk("Goodbye.\n");
module_init(test_init);
module_exit(test_exit);
MODULE_AUTHOR("dext0rb");
MODULE_LICENSE("LOL");
| improve this answer | |
  • \$\begingroup\$ appreciating your answer, But do you know how to do it from command line? \$\endgroup\$ – sdfsdfsdf Mar 15 '14 at 9:01
  • \$\begingroup\$ Yes. My answer implies you compile this code (or something like it) and run it on your distro. You access the proc filesystem from command line with the cat command. \$\endgroup\$ – dext0rb Mar 16 '14 at 1:17
