During RS485 transmission, what is the absolute voltage change in the TXD+ and TXD- pins in RS485? Do they swap value (IE if TXD+ is sitting at 4V quiescent, then it goes 4v 0v 4v during transmittion) or do they just move "differentially" (IE TXD+ goes 4v 3.5V 4v and TXD- goes 0v 0.5V 0V)?
Background - but not my actual question:
I'm trying to understand a problem that is being debugged (not by me) on a project that I'm associated with. I only get to hear about it from the side.
The explanation for the problem that I am hearing is that one RS485 device is using voltages (absolute) that are too far apart for the other device. That is to say: that the "master" has it's TXD+ and TXD- sitting at (say) 4v and 0v, wheras the "slave" can only cope with these being at 3V and 0V respectively.
This got me wondering how does the "differential" transmission work in the first place? When this master transmits alternating bits, does it swap TXD+ and TXD- between 0 and 4V, or does it do some small differential change on them, like dropping TDX+ to 3.5V and raising TXD- to 0.5V? Would that be valid?
If it's the latter, then I can understand the explanation. But if its the former, then the explanation makes no sense...
