I think I am right in saying that 8k UHD is the highest a screen can go, so is there a limit to the number of pixels on a screen, limit to what the eye can recognise or what is physically possible?
WOuld there be any point in going up to 1M one day for example?
closed as primarily opinion-based by Ignacio Vazquez-Abrams, Joe Hass, Daniel Grillo, alexan_e, Matt Young Mar 21 '14 at 2:28
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ The limit you are asking for is probably pixel density, not resolution. Theoretically you can put "as many" pixels as you like on a panel that is large enough. \$\endgroup\$ – Rev1.0 Mar 20 '14 at 8:28
I don't see any limits in the areas you suggest. It's true that the eye's ability to perceive detail is limited, if we want to take in the entire screen at once. But we can always look at just a portion of the screen at a time, as we do with murals, large paintings, the entire scenery around us :-). As for limits to manufacturing the screen, that's limited by power consumption (but reflective pixels can be very low power), CPU/GPU speed for calculating changing scenes, and the wiring or other schemes for communicating with the pixels. But none of those seem outright show stoppers (so to speak), just costs, which seem on a downward trajectory. Some people expect us to have vast walls of video wallpaper... and one doesn't heat categorical problems with that.
  • \$\begingroup\$ It could also serve as home heating. \$\endgroup\$ – Spehro Pefhany Mar 20 '14 at 11:30
