So I'm planning on building a skee ball machine and as I've been looking into it I've decided to use some seven segment displays from here:
7-segments display
As I've looked into this more I know I need a breadboard and I'm planning on using a solderless one found here
Breadboard
So my plan is to use an arduino to get input from the arcade machine and then hook up a raspberry pi to get information to the bread board and light up these displays (I'll have 7 seven segment displays, so I have enough to have the word "highscore" on display at one time).
I'm fairly new to this breadboard thing and want to know what wires I would need to connect these SSD (seven segment displays) to the breadboard. I've found a couple of different wires and they're all confusing me.
Here's the first one:
Jumpers
My fears with this one are:
  1. Will they be long enough, they look rather short. 2. Are they even the right type to connect
Here's the second one:
Jumpers 2
  1. What's the difference between the male and female ends compared to my first one?
  2. Will this one work?
So I'm really confused on which ones work and would appreciate some help and guidance and hopefully gain some knowledge of this.
    \$\begingroup\$ Any particular reason why you don't want to solder wire to the pins? \$\endgroup\$ Mar 20, 2014 at 14:43
  • \$\begingroup\$ Ooh you're right @Dave Tweed \$\endgroup\$
    – KodyVanRy
    Mar 20, 2014 at 14:46
  • \$\begingroup\$ Also i want to be able to rearrange pins later and also possibly use the board for other things without paying $50 to get a new set of displays and a new breadboard \$\endgroup\$
    – KodyVanRy
    Mar 20, 2014 at 14:49
  • \$\begingroup\$ You solder the wires to the segments, not the breadboard. \$\endgroup\$ Mar 20, 2014 at 14:50
  • \$\begingroup\$ OK, but i still would rather not, if it is absolutely necessary i will, but I'd prefer not \$\endgroup\$
    – KodyVanRy
    Mar 20, 2014 at 14:51
The wires you show are meant for both ends to be connected to the breadboard. They have nice and sturdy pins on the ends that are just right for the sockets in the breadboard.
However, if you want to connect points on the breadboard to something off the breadboard, like your 7-segment LEDs apparently, then these aren't appropriate. Fortunately single strand #22 wire works just fine in these breadboards too. Get a roll of it, cut each wire to the length you need, solder one end to the LEDs, then stick the other end into whatever socket in the breadboard you want.
