I bought a USB 32-Bit Whacker - PIC32MX795 Development Board and a MPLAB PICkit 3 after working with some ATmega stuff in the past.
These are the 6 pins(on the pickit). I'm looking for them on the whacker board. I can find
  • vpp
  • 3.3v
  • gnd
  • pgd
  • pgc
in a row, but i'm wondering 2 things
  • is vdd the same as 3.3v?
  • where / what / do I need the LVP?
  • \$\begingroup\$ The PIC data sheet and the PICkit 3 documentation will tell you what pins you need to connect. MPLAB should then work with it. \$\endgroup\$ Mar 21, 2014 at 19:02
  • \$\begingroup\$ the pickit has 6 output pins and most connectors on the dev board are 5.. so not sure which ones are correct. \$\endgroup\$
    – dansch
    Mar 21, 2014 at 19:18
  • \$\begingroup\$ Just use the first five pins on the PICkit 3. \$\endgroup\$ Mar 21, 2014 at 20:30
    \$\begingroup\$ You don't need LVP. \$\endgroup\$ Mar 22, 2014 at 15:21
Be sure to look through the datasheet for both the PIC32MX795 and the datasheet for the PicKit 3...These are explained in there. Also looking at schematics for dev kits can make this an easy problem to solve as well.
A quick googling revealed this as well
