I suspect this component to be a SMD microphone made by ST. Unfortunately I could not map the writings on the device to any SMD microphone datasheet issued by ST.
Do you have a clue?
SMD Microphone
  • \$\begingroup\$ This question appears to be off-topic because it is not about electronic design. \$\endgroup\$ Mar 24, 2014 at 13:48
You're correct, it's this one: http://www.st.com/web/catalog/sense_power/FM125/SC1564/PF251680
(It's the same one that's on the STM32F4 Discovery Kit)
