I am building a simple debouncer with decrementing counter. The syntitizer is yelling that there are latches. I don't need latches. I just need flipflops. WHich part in the following code is creating latches?
Design: The block receives a value and if the value is different from the stored one, it starts to count down. As soon as the counter reaches 0, the block outputs the new value.
library IEEE;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
entity Debouncer is
    Generic (
          DB_DATA_WIDTH             :   integer range 1 to 8   := 8;
          DB_CLOCKS                 :   integer range 0 to 1023   := 3
    Port(
        clk : in STD_LOGIC; --clock
        Sig : in STD_LOGIC_VECTOR (DB_DATA_WIDTH-1 downto 0);   --raw input signal
        Deb_Sig : out STD_LOGIC_VECTOR (DB_DATA_WIDTH-1 downto 0);
        Deb_Rdy : out STD_LOGIC;
        rst : in STD_LOGIC
    );--debounced output signal
end Debouncer;
architecture Behavioral of Debouncer is
    signal value_reg :STD_LOGIC_VECTOR (DB_DATA_WIDTH-1 downto 0);
    signal tick_counter : unsigned (9 downto 0);
begin
    process (clk, rst) is
    begin
        if (rst = '1') then
            --TO_UNSIGNED(DB_CLOCKS, tick_counter'length)
            tick_counter <= TO_UNSIGNED(DB_CLOCKS, tick_counter'length);
            value_reg <= (others=>'0');
        elsif (clk'event and clk= '1') then
            if (value_reg = Sig) then
                if (tick_counter /= 0) then
                    tick_counter <= tick_counter -1;
                end if;
            else
                value_reg <= Sig;
            end if;
        end if;
    end process;
    Deb_Rdy <= '1' when ( tick_counter = 0 ) else '0';--debouncing logic is assigned to the output Deb_sig
    Deb_Sig <= value_reg;
end Behavioral;
Log:
WARNING:Xst:1710 - FF/Latch <Inst_Debouncer/tick_counter_9> (without init value) has a constant value of 0 in block <led_switches>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Inst_Debouncer/tick_counter_8> (without init value) has a constant value of 0 in block <led_switches>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Inst_Debouncer/tick_counter_6> (without init value) has a constant value of 0 in block <led_switches>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Inst_Debouncer/tick_counter_5> (without init value) has a constant value of 0 in block <led_switches>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Inst_Debouncer/tick_counter_7> (without init value) has a constant value of 0 in block <led_switches>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Inst_Debouncer/tick_counter_3> (without init value) has a constant value of 0 in block <led_switches>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Inst_Debouncer/tick_counter_2> (without init value) has a constant value of 0 in block <led_switches>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Inst_Debouncer/tick_counter_4> (without init value) has a constant value of 0 in block <led_switches>. This FF/Latch will be trimmed during the optimization process.
  • \$\begingroup\$ There are no latches; that's not what the error messages are telling you. \$\endgroup\$
    – user16324
    Mar 27, 2014 at 11:57
I believe your synthesizer is telling you that you only need a 2 bit tick_counter since you made DB_CLOCKS 3 in this case. It isn't creating latches, it is trimming FF/Latches (in this case FF).
