I want to make a FSM model of FIR, for that I need to write FIR calculation code line in FSM implementation.
Here is the actual and correct code for FIR
entity fir_4tap is
  port(   Clk : in std_logic; --clock signal
          Clk_fast : in std_logic;
          --  Xin : in signed(7 downto 0); --input signal
          bit_in : in std_logic;
          bit_out : out std_logic;
          Yout : out signed(15 downto 0)  --filter output
end fir_4tap;
architecture Behavioral of fir_4tap is
  signal add_out3 : signed(15 downto 0) := (others => '0');
  signal index : unsigned(2 downto 0) := (others =>'0');
  signal counter : unsigned(3 downto 0) := (others => '0');
  signal p : unsigned(1 downto 0) := (others => '0');
  signal k : unsigned(1 downto 0) := (others => '0');
  signal j : unsigned(1 downto 0) := (others => '0');
  type array_signed is array(8 downto 0) of signed(7 downto 0);
  signal z : array_signed := (others => "00000000");
  type array_signed1 is array(3 downto 0) of signed(7 downto 0);
  signal H : array_signed1 := (others => "00000000");
  signal Xin : array_signed1 := (others => "00000000");
begin
  z(0) <= to_signed(-3,8);
  z(1) <= to_signed(1,8);
  z(2) <= to_signed(0,8);
  z(3) <= to_signed(-2,8);
  z(4) <= to_signed(-1,8);
  z(5) <= to_signed(4,8);
  z(6) <= to_signed(-5,8);
  z(7) <= to_signed(6,8);
  z(8) <= to_signed(0,8);
  H(0) <= to_signed(-2,8);
  H(1) <= to_signed(-1,8);
  H(2) <= to_signed(3,8);
  H(3) <= to_signed(4,8);
  process (clk)
  begin
    if (rising_edge(Clk)) then
      index <= index +1;
      if (index = "111") then
        Xin(to_integer(p)) <= z(to_integer(counter));                                              k <= p;
        p <= p + 1;
        ***-- This part of the code has problem, I want to write the line which is summing --up for add_out3 in a for loop.***
        add_out3 <= (others => '0');
        add_out3 <=  Xin(to_integer(k))*H(to_integer(j)) + Xin(to_integer(k-1))*H(to_integer(j+1)) + Xin(to_integer(k-2))*H(to_integer(j+2)) + Xin(to_integer(k-3))*H(to_integer(j+3));
        Yout <= add_out3;
      end if;
    end if;
  end process;
end Behavioral;
Now Below is the FSM implementation try by me but not getting the same out sample as input can somebody tell me what could be the problem in the code?
----------------FSM implementation of the FIR filter ---------------------
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity test is
end test;
architecture Behavioral of test is
signal data_buffer : signed(7 downto 0) := (others => '0');
signal input : signed(7 downto 0) := (others => '0');
type MULT_TYPE is array(3 downto 0) of signed(15 downto 0);
signal MULT_array : MULT_TYPE := (others => "0000000000000000");
type ADD_TYPE is array(3 downto 0) of signed(15 downto 0);
signal ADD_array : ADD_TYPE := (others => "0000000000000000");
constant ZERO : signed(15 downto 0) := (others => '0');
type state_type is (s0,s1,s2,s3);  --type of state machine.
signal current_s : state_type := s0;  --current and next state declaration.
signal next_s : state_type := s0;
signal reset : std_logic := '0';
signal go : std_logic := '0';
signal change_state : std_logic := '0' ;
signal counter_FSM_monitor : unsigned( 6 downto 0) := "0000000";
begin
process (Clk) is
begin
if falling_edge(Clk) then
data_buffer(to_integer(index)) <= bit_in;
index <= index +1;
input <= z(to_integer(counter));
counter <= counter + 1;
if(counter = "1000") then
counter <= "0000";
end if;
end if;
end if;
end process;
process (clk_fast)
begin
if (falling_edge(clk_fast)) then
counter_FSM_monitor <= counter_FSM_monitor + 1;
if( to_integer(counter_FSM_monitor) = 76) then
counter_FSM_monitor <= "0000000";
end if;
case change_state is
when '1' =>
current_s <= next_s;   --state change.
when '0' => --current_s <= s0;
when others =>
end case;
end if;
end process;
Process(current_s,input)
begin
if ( to_integer(counter_FSM_monitor) < 64 ) then
-- waiting for the Input
elsif (to_integer(counter_FSM_monitor) >= 64 and to_integer(counter_FSM_monitor) < 76) then
---------------------------------------------- FSM ----------------------------------------
case current_s is
when s0 =>
mult_array(0) <= input*H(3);
ADD_array(0) <= ZERO + mult_array(0);
next_s <= s1;
change_state <= '1';
when s1 =>
mult_array(1) <= input*H(2);
ADD_array(1) <= mult_array(1) + ADD_array(0);
next_s <= s2;
when s2 =>
mult_array(2) <= input*H(1);
ADD_array(2) <= mult_array(2) + ADD_array(1);
next_s <= s3;
when s3 =>
mult_array(3) <= input*H(0);
ADD_array(3) <= mult_array(3) + ADD_array(2);
Yout <= ADD_array(3);
next_s <= s0;
when others =>
next_s <= s0;-- never comes here
end case;
end if;
end process;
end Behavioral;
I am not able to receive the same output which I received by the first code with FSM model. FSM code gives the correct output for the first out but from the second out sample it gives wrong result.Can somebody tell me what I am doing wrong ?
  • \$\begingroup\$ Duplicate of stackoverflow.com/questions/22326167/fsm-model-of-fir-filter/… \$\endgroup\$
    – user16324
    Commented Mar 27, 2014 at 11:39
  • \$\begingroup\$ yes, I have heard that many experienced persons in the vhdl and electronics are on the electronics.stackoverflow and not on stackoverflow. Chances of getting some suggestions/help probably increases by posting the question here, As I didn't get a satisfactory response there. \$\endgroup\$ Commented Mar 27, 2014 at 12:07
    \$\begingroup\$ If you want a better answer than the one you accepted, pose a better question. Nobody's going to write a testbench and debug this lot for you. Write your own testbench and compare the intermediate results between your two (working but too big) and (not yet working FSM) versions. Where they differ, work out why and fix it. \$\endgroup\$
    – user16324
    Commented Mar 27, 2014 at 12:17
Your second "FSM" code has many problems, primarily in the last process — process (current_s, input). Just a few examples to start with:
  • This is an asynchronous process, so you must list all of the signals used inside of it in the sensitivity list. Failing to do this means that the simulation will not match the behavior of the actual hardware.
  • Since not every output is assigned on every possible path through the code, you're creating an enormous number of implicit latches, which will probably simulate OK but give you lots of problems in synthesis.
In addition, this is a poorly-asked question:
  • You didn't document the relationship between Clk and clk_fast.
  • You didn't format (e.g., indent) the code to make it easy for others to follow.
  • You didn't comment the code so that we could figure out what your intent was.
Anyway, in general, an FSM is not the recommended approach for this sort of problem. What you really need to do is set up a pipeline to do the FIR arithmetic. This would allow you to eliminate the fast clock altogether, along with the complicated FSM logic. The module will produce the same output as the original module, except that it will be delayed by the number of stages in your pipeline.
