To begin, I've thoroughly searched for answers to my question/s and have yet to find any clear & concise data.
I'm in the progress of determining an appropriate N-Channel MOSFET to be used as a switch for an array of LED's. I need to remain in the SOA (safe operating area) of the MOSFET which is generally determined by a chart in the datasheet based on current and drain source voltage (\$V_{DS}\$).
The LED array will be composed of 2 strings of 10 LEDs (20 total) and use 1 A of current at 36 V.
The anode of the first LED in the strings will be connected to the 36 V power rail and the cathode of the last will be connected to the drain on the MOSFET. The source will be connected to ground.
The question I pose is this... How do I determine the \$V_{DS}\$ to be used in the SOA chart in my application?
Initially I assumed that I should be looking for a MOSFET that has a \$V_{DS}\$ of 36 V and current of 1 A that falls within the Safe Operating Area. But as I thought about it further, the MOSFET will never be exposed to 36 V because each LED diode has a forward voltage drop and the MOSFET itself will be at the end of the chain. Am I being led astray with this assumption?
