I have 8 wires, and I want to count how many of these are in a high state and convert this to a 3-bit binary signal. If the count of inputs that are high is greater than 4, I don't care what exact amount of inputs are on beyond that point, I just need to know whether more than 4 are high. So I only need 3 bits of output, if that makes sense.
i.e. if 1 wire is on, output 001, if 2 wires on on, output 010, etc. and if 7 or 8 wires are on output 111.
Is there an IC that can help me do this easily?
    \$\begingroup\$ You statements are contradictory. First, you say that you don't care exactly what number are high if 4 or more are high, then you say the output should be 111 of 7 or 8 are high. Please provide a chart of inputs high vs. output bits. \$\endgroup\$
    – DoxyLover
    Commented Mar 27, 2014 at 19:48
  • \$\begingroup\$ Sorry for the confusion. Well, since I need to know whether the output is greater than 4, I need 3 bits of output anyways. So really anything signaling greater than 4 works, I figured the most likely way to do it would be just count normally until 8 is reached, and when that happens just count that as a 7. \$\endgroup\$
    – Gus
    Commented Mar 27, 2014 at 19:56
    \$\begingroup\$ The answer you accepted is wrong. This is a good example of why you should wait a little while before accepting something. You want to give various people a chance to chime in, and for the peer review process to tell you which answers are right and which ones are wrong. \$\endgroup\$ Commented Mar 27, 2014 at 20:42
7
This is a simple job for a microcontroller. Spehro correctly points out that it can be accomplished with a simple lookup. If you can tolerate lower speed then counting the bits in a loop will do it too, but will take less code space.
Another way is to do this in analog. Put a 100 kΩ resistor in series with each digital output, then feed that into a comparator. If 4 out of 8 are high, then you get 0.50 of the supply voltage. If 3 out of 8 are high, then you get 0.38 of the supply voltage. Set the comparator threshold to 0.44 of the supply and it will distinguish between 4 or more, and 3 or less.
  • \$\begingroup\$ If there's a spare ADC input that would work too. \$\endgroup\$
    Commented Mar 27, 2014 at 21:12
7
A microcontroller could do it very easily. Since there are only 256 possible combinations, a simple lookup table would be the fastest way. (I did the below outputting 8 for all high for consistency, you can change the last entry to 7 if you want).
The code could look something like this:-
unsigned char lut[256] = {0x0, 0x1, 0x1, 0x2, 0x1, 0x2, 0x2, 0x3, 0x1, 0x2, 0x2, 0x3, 0x2, 0x3, 0x3, 0x4, 0x1, 0x2, 0x2, 0x3, 0x2, 0x3, 0x3, 0x4, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x1, 0x2, 0x2, 0x3, 0x2, 0x3, 0x3, 0x4, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x1, 0x2, 0x2, 0x3, 0x2, 0x3, 0x3, 0x4, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x4, 0x5, 0x5, 0x6, 0x5, 0x6, 0x6, 0x7, 0x1, 0x2, 0x2, 0x3, 0x2, 0x3, 0x3, 0x4, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x4, 0x5, 0x5, 0x6, 0x5, 0x6, 0x6, 0x7, 0x2, 0x3, 0x3, 0x4, 0x3, 0x4, 0x4, 0x5, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x4, 0x5, 0x5, 0x6, 0x5, 0x6, 0x6, 0x7, 0x3, 0x4, 0x4, 0x5, 0x4, 0x5, 0x5, 0x6, 0x4, 0x5, 0x5, 0x6, 0x5, 0x6, 0x6, 0x7, 0x4, 0x5, 0x5, 0x6, 0x5, 0x6, 0x6, 0x7, 0x5, 0x6, 0x6, 0x7, 0x6, 0x7, 0x7, 0x8};
    <some initialization stuff>
    for(;;) out_port= lut[in_port];  // do this forever
I don't know of any logic chip that has this exact functionality. Priority encoders do something a bit different.
If you needed really fast response time, you could program a nonvolatile memory with the lookup table, or use programmable logic.
Shouldn't a 4-bit full adder do the trick?
http://nl.farnell.com/texas-instruments/cd74hc283e/logic-4bit-binary-full-adder-16dip/dp/1750337
  • \$\begingroup\$ Good idea, but...no. The OP wants to count bits, so for example the result from 1010 would be 2 (0011). The adder adds; it doesn't count. \$\endgroup\$
    – gbarry
    Commented Mar 31, 2014 at 20:30
