I stripped a DB9 extension cable which I will use to connect to a DB9 connector on one end and an RJ45 on another. I need to make connections to pin 2, 3, and 5 on the DB9 side.
When I stripped the DB9 wire, I was surprised to find 5 wires, since there are 9 pins in a DB9 connector. Why are there 9 pins but only 5 wires?
One of the wires is unshielded. Why is that? The other wires are red, brown, orange, and black. Which pins do these go to?
