I'm a software developer looking to prototype an application that requires input from a 3-axis accelerometer, ideally via Bluetooth LE. Current specs on the accelerometer are +/-50G sensing range with +/-5% precision and at least 1kHz sample rate, ideally with peak sampling.
My primary question is whether I can do this with off-the-shelf hardware and APIs? If so what are good sources and standards, especially if I want to mass-produce the hardware?
E.g., can I pay up for an integrated prototype device that meets those specs and comes with an API that encapsulates the Bluetooth, self-test, and other hardware interaction, so I can just get to work on the software problem?
Or is this still a "hard"/custom electronics problem? If so is the Bluetooth requirement itself tricky, meaning I should start with a wired connection to the accelerometer and deal with Bluetooth integration later?
