I'm building a MindFlex-based EEG. Basically, I'm sniffing a 9600bps bus, analyzing the data with an Arduino*, and sending it to Processing/Java for display. To make it absolutely isolated from mains power, I want to make it wireless, but the only wireless gear I can afford (transmitter, and its matching receiver) transmits at 2400bps. I think that if I move the Arduino into the headset, I can make a SoftSerial connection at 2400bps to operate the transmitter, then use hardware serial at 9600bps to talk to the headset. That way, I can hook up a reciever to a FTDI USB-TTL adaptor and send the data to Processing.
Will that work? If it helps, new data comes from the headset about once per second, and I plan on implementing a timestamp into the data from the Arduino, so lag shouldn't be too much of an issue. I also cannot afford XBees, Bluetooth, or anything else.
*Before anyone says anything, if wireless works, I will use an Arduino Pro Mini, and if it doesn't I'm going to use a BoArduino - I'm not throwing an entire Uno at this project.
