I have Code for Mod bus Library as below. I have Gone through lots of forum. How to assign device ID, slave address, length using below library function:
#include <SimpleModbusSlave.h>
#define  LED 9
enum
  ADC_VAL,
  PWM_VAL,
  HOLDING_REGS_SIZE // leave this one
unsigned int holdingRegs[HOLDING_REGS_SIZE];
void setup()
  modbus_configure(&Serial, 9600, SERIAL_8N2, 1, 2, HOLDING_REGS_SIZE, holdingRegs);
  pinMode(LED, OUTPUT);
void loop()
  modbus_update();
  holdingRegs[ADC_VAL] = analogRead(A0); // update data to be read by the master to adjust the PWM
  analogWrite(LED, holdingRegs[PWM_VAL]>>2); // constrain adc value from the arduino master to 255
I am getting Error has.
SimpleModbusSlaveArduino.cpp: In function 'void setup()':
SimpleModbusSlaveArduino:79: error: 'SERIAL_8N2' was not declared in this scope
Let me know how to resolve issue.
  • \$\begingroup\$ Link to the library? \$\endgroup\$ Apr 1, 2014 at 11:52
  • \$\begingroup\$ Its being already added, How to link library?? \$\endgroup\$
    – AMPS
    Apr 1, 2014 at 12:08
  • \$\begingroup\$ Sorry, I wasn't clear - could you give us a link to the library you're using? It is difficult to diagnose your problem otherwise. \$\endgroup\$ Apr 1, 2014 at 12:10
  • \$\begingroup\$ @AMPS Just FYI. There is now a stack dedicated to Arduino arduino.stackexchange.com \$\endgroup\$ Apr 1, 2014 at 15:38
Open up SimpleModbusSlave.c. Check the format of modbus_configure() matches what you have.
Open up SimpleModbusSlave.h. Check the define for SERIAL_8N2 exists.
I'm guessing it should be
modbus_configure(9600, 1, 2, HOLDING_REGS_SIZE);
