I have a STLM20 temperature sensor with the following transfer function:
$$V_{0}=\frac{-11.69\text{mV}}{C \cdot T} + 1.8663 \text{V}$$
I have solved it for \$T\$ and it should be:
$$T=85.543\cdot (1.8663-V_{0})$$
Is this correct?
  • \$\begingroup\$ It is correct and strictly speaking this is a math question - applied algebra. \$\endgroup\$ – Andy aka Apr 3 '14 at 20:46
    \$\begingroup\$ Technically that's a scaling equation, not a transfer function. \$\endgroup\$ – Matt Young Apr 3 '14 at 20:52
  • \$\begingroup\$ @MattYoung I think this could accurately be described as the inverse transfer function of the sensor, since it gives degrees C as a function of volts. \$\endgroup\$ – Spehro Pefhany Apr 3 '14 at 20:54
That's correct, and it's the best linear equation for the range 20°C< T <30°C, however you can get better accuracy over a wider range by using the quadratic solution:
According to the data sheet.
| improve this answer | |
