I'm planning to do some audio DSP soon but I would like to know if I can connect an ADC directly to a DAC without a processor in the chain. My main reason is to test preamp circuitry. I would like the ADC and DAC to be 24-bit at 48 kHz, and I have many options ADC and DAC-wise. I would also like to use I2S for communication so when I add a DSP, it will work seamlessly.
Is it as simple as connecting the clock and data lines?
  • \$\begingroup\$ mention the exact partnumbers or parts u r going to use...then it is easy to answer.... \$\endgroup\$ – user19579 Apr 9 '14 at 5:20
It would depend on the parts you're using. ADCs and DACs are more likely than not going to be slaves that would expect some controller to give them a clock signal.
If you want to test a preamp, could you just use a signal generator in place of the DAC output? That, or design in whatever DSP you want to use and write some quick code that simply passes values through.
