I understand that we use the multi_cycle path when the delay between launch and latch register shall be more than 1 clock cycle. With a HDL design how can one predict that the combinational logic between two registers shall be more than clock cycle and thus there is need to use the multi_cycle path constraint? Besides this, for a HDL design where we may not know exactly which registers we are talking about, how can we put in a multi_cycle path constraint? Is it important that this delay be more than 1 clock cycle under best as well as worst conditions?
As far as I understand. We first synthesize our design and if the propagation delay of the gates is big enough between two registers than we know we need this constraint. This shall happen before the fitter as after fitting the routing delay shall add up as well. Is this correct?
Can we also force the fitter to fit logic in such a way that it takes 2 clock cycles for data to reach the latch register? My confusion exists because when we have a HDL design we are at a higher level of abstraction and don't know about all the physical registers that exist in the design, that is unless and until we do a STA on the post-synthesis netlist.
You've asked a number of very general questions, so my answers will necessarily be very general as well. If you have a specific example you'd like to discuss, add it to your question.
It is implicit in the design. If you require the result to be available in one clock cycle (as specified by the behavior), the clock cycle will need to be as long as required to allow this to happen. If the behavior is written so as to allow 2 or 3 clock cycles for the result, then this is when you also need to add the multi-cycle constraint. You don't do the latter without also doing the former.
At this point, you need to abandon the high-level abstraction and dig down into the implementation details as provided by the synthesis tools. It can be tricky at first to decipher the reports, but it becomes easier with experience.
No.
Sort of. The synthesis tools will work hard to implement the logic so that it meets the timing constraints you have already established, including routing delays. If it can't, it will tell you.
Advanced tools even know how to move logic from one side of a register to another in order to balance the propagation delays, minimizing the clock period required.
In general, no. But there's no real need to do this.
High levels of abstraction a fine to a point, but if you really care about getting the most performance out of your design, you need to be willing to work down at the RTL (register-transfer level) code, in which you do explicitly know where the registers are and what logic goes between them.
My own background is that of an EE, so I always write my synthesizable code as RTL, since that's how I think about the hardware design. I only use higher-level, purely behavioral code in my simulation testbenches, which are never intended to be synthesized.
  • \$\begingroup\$ Lets put it another way than. Assuming I have made a design and I compile it and see there are plenty of timing violations. Now under these circumstances, how do I know if I should use multi cycle path to get rid of some of these violations and make it easier for the fitter? I mean we won't necessarily know about such problems until we have done the whole compilation and fitting cycle to begin with right? \$\endgroup\$
    – quantum231
    Apr 11, 2014 at 11:42
  • \$\begingroup\$ Actually, you should know, but this is something that you learn from experience. At first, you should expect to make many iterations through the optimization process. And like I said before, you don't simply add multi-cycle path constraints without also changing the design to actually create the multi-cycle paths. If you simply declare a long combinatorial path to be "multi-cycle", you'll get timing closure, but the circuit won't function correctly. \$\endgroup\$
    – Dave Tweed
    Apr 11, 2014 at 12:27
  • \$\begingroup\$ Wow Dave, thank you very much. A very ancient confusion is now resolved in my mind :D \$\endgroup\$
    – quantum231
    Apr 17, 2014 at 14:23
