Seems like I can't restart USB modem in Linux, so I setup an arduino gig to emulate usb modem plug/unplug.
I have Arduino Uno R3 and several N-channel mosfet https://www.sparkfun.com/products/10213, and used the setup in http://bildr.org/2012/03/rfp30n06le-arduino/ for switching the ground wire of the usb modem on/off.
This works, for a while, then the usb hub started to have problem. I think I have to really emulate USB plug/unplug, that is, cutting off both the power wire and the data wire of the usb modem.
The problem is, while the USB power has +5V and ground, the data has D+ ~+2.5V and D- ~-2.5V, they doesn't have a common ground, to be used with the setup using N-channel mosfet.
What should I do? if I buy another arduino uno just for the data wire, I still have problem, the data ground is not the same with the arduino ground (I think N-Mosfet requires a common ground), I don't know if this will cause problem.
Do I need a DC voltage step-up component? or is there other solution.
I'm thinking how usb plug works, is first connect the power wire, wait some micro seconds then connect the data wire, with unplug the opposite.
