6
Considering the circuit below.:
What is the purpose of capacitor C5? I know it provides positive feedback to sustain the LC oscillations, but how does this work ?
    \$\begingroup\$ I think you need to be more specific about what you don't understand - clearly you understand that it provides positive feedback so what don't you understand - maybe you don't understand that the emitter can be an input? Or maybe you don't recognize that the final transistor is common-base configuration (regarding the carrier)? Or maybe you don't understand how the reverse biased base-collector can modulate the output carrier? \$\endgroup\$
    Apr 11, 2014 at 18:38
  • \$\begingroup\$ I understand all the points that you have mentioned. What is dont understand, is does just connecting a capacitor from output to input create a feedback ? \$\endgroup\$ Apr 12, 2014 at 11:04
  • \$\begingroup\$ That's the normal way feedback happens - using a capacitor or resistor. \$\endgroup\$
    Apr 12, 2014 at 11:18
  • \$\begingroup\$ Why would only a part of the collector voltage go back to the emitter ? The capacitor is a low impedance for high frequencies, so wouldn't all of the output just go through the capacitor ? \$\endgroup\$ Apr 12, 2014 at 11:30
    \$\begingroup\$ The emitter, as an input is very low impedance, probably in the order of ten ohms. I estimate this oscillates at about 50 MHz. At that frequency the 5pF has an impedance of over 600 ohms. \$\endgroup\$
    Apr 12, 2014 at 11:47
Check this puppy out. http://www.boondog.com/tutorials/rfTransmitter/rfTransmitter.htm
The C5 capacitor across the transistor serves to keep the tank circuit vibrating. In theory, as long as there is a supply voltage across the parallel inductor and variable capacitor, it should vibrate at the resonant frequency indefinitely. In reality however, the frequency decays due to heating losses. C5 is used to prevent decay.
For a circuit to oscillate it is necessary to have a LOOP GAIN of unity (Barkhausen criterion). Hence, the amount of output voltage that is fed back to the input of the amplifying unit depends on the gain (magnitude and phase!). In the present case, only a part of the output voltage is created across the impedance seen at the emitter node because of the voltage division rule. This emitter node impedance is \$re=r6||(1/gm)\$ with \$gm=transconductance\$.
For the circuit shown, the exact calculation of loop gain is rather involved since the feedback circuit (C5-re) acts as an additional load for the transistor and, hence, must be considered for gain calculation (in parallel to the LC tank). Something similar applies to the phase. Because the feedback path (high-pass C5-re) creates a certain phase shift (the capacitor C5 CANNOT be regarded as a short for "high frequencies") the resulting oscillation frequency will NOT be identical to the resonant frequency of the LC tank. Instead, there will be a small frequency shift.
If the base is kept fixed and the emitter voltage is reduced, the transistor sees a higher voltage between the base and emitter and it is turned ON harder. If the voltage on the emitter increases, the transistor turns OFF as the difference between the two is reduced. This is exactly what happens in this circuit. The 5pF capacitor between the collector and emitter influences the voltage on the emitter to turn the transistor on and off. It does this by constantly monitoring the voltage on the tuned circuit and passing the change to the emitter. The above fact combined with the fact that the capacitor has an impedance of about 600 ohms at 50 MHz, and so only a part of the output is fed back to the input. I think this answer gives me closure. Is my understanding right, even if it is really basic ?
