Does TI Tiva C uC ADC input is 5V tolerant ?
EDIT:
Found ADC parameters in datasheet http://cl.ly/image/3D1Q3q09470J. Please don't down vote.
Thanks
    \$\begingroup\$ What does the data sheet say? \$\endgroup\$
    – Joe Hass
    Apr 12, 2014 at 19:13
  • \$\begingroup\$ Thanks. cl.ly/image/3D1Q3q09470J << I'm not sure, but maximum ADC input is Vdda. And Vdda is 3.63V. So I think Tiva ADC is not 5V tolerant. \$\endgroup\$
    – kesrut
    Apr 12, 2014 at 19:19
You need to look at the table called "Absolute Maximum Ratings" if you want to know if the chip will tolerate 5 volts (as opposed to function properly) on the analog inputs. It looks like some pins (at least when used as GPIOs) can tolerate up to 5.5 volts while others are limited to 0.3 volts above Vdd.
