I'm trying to implement a 8 to 3 priority encoder which worked quiet well.
My function for the three outputs are:
$$A_0 = e_1 + e_3 + e_5 + e_7$$ $$A_1 = e_2 + e_3 + e_6 + e_7$$ $$A_2 = e_4 + e_5 + e_6 + e_7$$
Now I want to add an output which shows if more then one input is active. If only one input is active the valid output should be 1 otherwhise 0.
I don't know how to implement my valid function with AND, OR and NOT gates.
Does anyone have a hint for me?
EDIT:
This is a draft of the valid function:
V(e7,e6,e5,e4,e3,e2,e1)=
if e7=1 and e6=0 and e5=0 and e4=0 and e3=0 and e2=0 and e1=0 then return 1
else if e7=0 and e6=1 and e5=0 and e4=0 and e3=0 and e2=0 and e1=0 then return 1
else if e7=0 and e6=0 and e5=1 and e4=0 and e3=0 and e2=0 and e1=0 then return 1
else if e7=0 and e6=0 and e5=0 and e4=1 and e3=0 and e2=0 and e1=0 then return 1
else if e7=0 and e6=0 and e5=0 and e4=0 and e3=0 and e2=0 and e1=1 then return 1
The truth table looks like the following:
The problem with the truth table is that I'm not able to create a kv diagram with 8 variables.
