I have a Arduino sketch I am trying to use to control a DC motor using PWM. It seems it it just running the motor as if I the PWM was set to 255 (100%). I intend for my sketch to start the motor slowly (0) and increase every 30ms to 255, then back to 0. However it just seems to run at 100%. Any thoughts? Here is my code.
int con = 5;
int amm = 0;
void setup(){
  pinMode(con, OUTPUT);
void loop(){
  analogWrite(con, amm);
  amm = amm + 1;
  if (amm = 255) {
    amm == 0;
  delay(30);
Am I missing something? I don't code alot in C so maybe I did my loop or variables wrong? Thank you for your help!
    \$\begingroup\$ Your if statement uses the wrong operators. "=" is assignment and "==" is comparison. I think you have them swapped. \$\endgroup\$ – Peter Apr 13 '14 at 22:43
  • \$\begingroup\$ @freyyr Thanks so much for your suggestion, changing my equal signs did the trick. Such a simple thing, can't believe I missed it. Awesome though to get it working! Thanks!!!! \$\endgroup\$ – 0xhughes Apr 14 '14 at 4:06
    \$\begingroup\$ In this specific case you can change int amm = 0; to uint8_t amm = 0; and remove the entire if statement. The amm variable will automatically overflow from 255 to 0. Good exercise to read up on how that works. \$\endgroup\$ – jippie Apr 14 '14 at 5:54
unless im reading this wrong , i would change if(amm = 255)to if(amm == 255) you need a extra =, and then inside the brackets change amm == 0; to amm = 0; src : http://en.wikipedia.org/wiki/Operators_in_C_and_C%2B%2B
  • \$\begingroup\$ Awesome! I am not very familiar with C, and I mixed up my equal signs. I feel like such a green horn ;) Thanks so much for pointing out this simple mistake! \$\endgroup\$ – 0xhughes Apr 14 '14 at 4:05
