I need to convert the output of differential output DAC to single ended. It's a 2 Vpp signal with a 1 V common-mode output. The output is 100 ohms. Should I use a transformer or a instrumentation amp. to do this conversion? The output could be up to 10 MHz (it's a communication signal) and the power is < -10 dBm.
Update 1 Since the signal is a RF communications signal, there is no DC component.
Update 2 Avoiding a +/- power supply would be nice, so in that case, a transformer would be better, correct?
