I have a input source from 50mV to 4V and I want a fixed/regulated voltage of 3V. Input voltage is varying every time so in order to achieve the 3V I have to implement Buck as well as Boost converter with respect to the input voltage.
I couldn't find any chip/IC which operates at such a low voltage 50mV, So what could be the solution for this? Do I need to detect the input voltage before using Buck/Boost converter?
  • \$\begingroup\$ 50mV does not seem like a power input to me. Are you trying to amplify a signal or get power from a very low voltage power source? \$\endgroup\$
    – user36129
    Commented Apr 14, 2014 at 7:54
  • \$\begingroup\$ Do you have an idea of duration of input at each level? What current sourcing is possibly at each voltage level? \$\endgroup\$
    – Joe
    Commented Apr 14, 2014 at 14:32
  • \$\begingroup\$ There are buck-boost and boost-buck (aka Çùk converter) that do what you want. But for such input, you may need to consider other solutions. \$\endgroup\$
    – K. Rmth
    Commented Jul 16, 2015 at 6:39
50mV as a power source is energy harvester range, meaning the device operation will be sporadic at best. There are few devices from Linear which start working from ~200mV, depending on the energy source.
  • \$\begingroup\$ The energy source is thermal, the voltage varies from 50mV to 4V so if I want to get 3 V at the output I will have to use Buck as well as boost depending on the input voltage, is there a way to detect what voltage is coming? I did see some IC from LT but didn't really find the exact one I am looking for. \$\endgroup\$ Commented Apr 14, 2014 at 8:05
    \$\begingroup\$ I think it will be enough just to apply a load to the energy source for the voltage to drop. \$\endgroup\$
    – Lior Bilia
    Commented Apr 14, 2014 at 8:09
