I just want to clarify with everyone that I have exhausted all of my search options looking for an answer, and still cannot find the answer to my problem.
I am trying to interface a micro sd card slot with my pic32 project by bit banging an spi. I've had no problem initializing, and I can read the OCR and CSD register just fine, but when I send the read sector command, I get 512 Bytes of 0's no matter what.
I have tried with multiple cards with the same result with all. I am using SanDisk 2GB standard MicroSD cards. They are formatted as FAT(FAT16) by both Windows and using the SDFormatter provided by sdcard.org. I've used Disk Investigator to confirm that the MBR contains the correct data.
Here is the sequence I am using to initialize:
//Low speed
Send 10 Bytes of data to 'wake up' card w/ CS High
Send CMD0 to reset until response is idle (0x01)
Send CMD8 w/ arg 0x1AA and read correct response to verify SDC V2
Send ACMD41 w/ HCS flag to initialize until no longer idle (0x00)
//High speed
Send CMD58 to read OCR and check CCS flag in response
Send CMD16 to set block length to 512 Bytes
//At this point I should be able to read the MBR but get nothing
Send CMD17 /w arg 0x00 to read very first sector
When I send the read command, I do get a correct R1 response 0x00, then a few Byte transfers later, I get 0xFE indicating the start of data, but the data line just goes low for 512 Bytes, and nothing is read.
I've tried writing to a sector with dummy data, getting the 'data accepted' response, but when I tried to read it back, I got all zeros again. I'm wondering if I'm doing anything wrong with my initialization.
I'm sure it's not a problem with my program sending the wrong command, as I have everything hooked up to a scope, and everything seems to be correct. Here are the screenshots:
Here is the read sequence I am sending
And immediately following, the response I get
Any insight into why this is not working would be appreciated. I've spent much more time on this than I'd like, and like may things, it's probably a simple problem I'm not seeing. I'm hoping extra sets of eyes will spot my problem. Thanks in advance, and I will update with any information needed to help solve this problem.
EDIT, more things I've tried:
I've set the CS low for the entire read sequence, and no change in response.
I've changed the fixed CRC to the actual CRC needed by the read sequence, no change in response.
Using Disk Investigator to read the card on the computer, I can see the expected result from reading the first sector as shown:
0000 EB 00 90 20 20 20 20 20 . . . 0008 20 20 20 00 02 40 01 00 . . @ . . 0010 02 00 02 00 00 F8 EC 00 . . . . . . . . 0018 3F 00 40 00 87 00 00 00 ? . @ . . . . . 0020 79 EF 3A 00 80 00 29 10 y . : . . . ) . 0028 41 2E 17 4E 4F 20 4E 41 A . . N O N A 0030 4D 45 20 20 20 20 46 41 M E F A 0038 54 31 36 20 20 20 00 00 T 1 6 . . 0040 00 00 00 00 00 00 00 00 . . . . . . . . ---- All Zeros ------------- --------------- 01F0 00 00 00 00 00 00 00 00 . . . . . . . . 01F8 00 00 00 00 00 00 55 AA . . . . . . U .
List of Miso and Mosi blocks during init (formatted as o-scope picture):
// wake up with 80 clk pulses w/ cs high not shown here // First CMD0 send: 00 00 00 00 00 00 3F 01 40 00 00 00 00 95 FF FF //Second CMD0 send: FF FF FF FF FF FF FF C1 7F 40 00 00 00 00 95 FF FF FF //Third CMD0 send: FF FF FF FF FF FF FF 01 FF 40 00 00 00 00 95 FF FF FF //CMD8 w/ 0x1AA arg FF FF FF FF FF FF FF 01 00 00 01 AA FF 48 00 00 01 AA 87 FF FF FF FF FF FF FF //ACMD41 w/ HCS flag 6 times before 00-vv FF FF FF FF FF FF FF 01 FF FF FF FF FF FF FF FF 01 FF 77 00 00 00 00 95 FF FF FF 69 40 00 00 00 95 FF FF FF //CMD58 read OCR FF FF FF FF FF FF FF 00 80 FF 80 00 FF 7A 00 00 00 00 95 FF FF FF FF FF FF FF //CMD16 to set block length FF FF FF FF FF FF FF 00 FF 50 00 00 02 00 95 FF FF FF After this is the read function shown above
0x55 0xAA
. \$\endgroup\$ – Turbo J Apr 15 '14 at 19:22
