I'm trying to export an 8" square design that is mostly copper to Gerber files. The top layer file size is about 14 MB and the board house is complaining that it is crashing their software.
Is there any way to get Eagle to treat the copper areas differently as to not make the Gerber files huge. I'm currently using the Extended Gerber format.
I've read that it has something to do with the representation of the copper layers but I don't know how to change its representation in Eagle CAD.
From "Gerber File Problem 6 – Vector Fills" in a document by bayareacircuits.com:
Often plane layers or layers with shield areas come in filled with 1 mil or 2 mil vectors. This causes the Gerber file to be quite large in size and requires us to try and contourize the data. When you panelize this type of data the files often become too large for our plotter to digest. It is better for areas to be filled using “raster” or “contour” data.
In Eagle, the copper "polygons" are made up of many parallel overlapping traces. If the polygon's linewidth is set to something small, like 1 mil, it quickly consumes large amounts of data when converted to Gerber.
If you change the polygon's linewidth to something thicker, it will solve this problem. However, it also affects any thermals tied to the polygon, and can cause the polygon's borders to change.
If you need your current polygon settings, then I would suggest that you make a small-width, detailed polygon where it is important, and make a larger, coarse one over the rest of that layer.
  • \$\begingroup\$ Wow, thanks! That was dead on, the file went from being 14MB to about 600KB... \$\endgroup\$
    – pdel
    Apr 17, 2014 at 0:27
  • \$\begingroup\$ Glad to help :) \$\endgroup\$
    – bitsmack
    Apr 17, 2014 at 0:38
  • \$\begingroup\$ many thanks for your explanation ! It took me over a day to find the reason for this problem. Hallelujah !! Now the gerber generation takes less then a second, instead of 4 hours. \$\endgroup\$
    – Jeremy
    Jul 21, 2017 at 9:44
