Basically I want to create a blinking unit to drive my LED's. The LED's are used to be driven at a frequency of ~1.5Hz (that made me choose the values of L and C).
So here is my schematic. (I am physicist so there might be some issues with current direction...)
(The PNP is used to block the supply-current if the capacitor is charged.)
After a while of thinking about it I got to the point that this wont work because the resistance in the LC-circuit will cause that there wont be any oscillation. Even if in D3 is only a single LED...
And now I have no idea how to get my 12V DC current into a 12V AC current with a frequency of 1.5Hz. I searched a long time how to do this but I don't get it how to get it working.
I found i.e. circuits of power inverters but all of them (I found) are at 50Hz and 230V AC output.
How could I get it working to transform my 12V DC to 12V AC (f=1.5Hz) without using an IC. Well I thought of using a quartz but no one I found has a sufficient low frequency...
