I have a circuit which switches on by sending current to the base of one of its transistors. I'm trying to make receiver which can receive signals from a AM transmitter and send current to base of transistor so that circuit can switch on the circuit. I know how can I make AM transmitter. Given that I cannot use any receiver module/chip etc, please suggest a simple circuit design which can serve the purpose.
EDIT: I need a receiver with minimum range of 500-700meters. I have made this AM transmitter. As stated above I'm not trying to send audio signals, the circuit stays on as longs as current is passing through base of transistor. I want the circuit to stay on as long as transmitter is sending signals to receiver. What modifications I have to make in transmitter circuit for that.
