I would like to check total capacity of 64Ah lead "car battery" ^ by fully charging it and currently I have only older intelligent charger (Robbe Power Peak 8467). It directly supports charging modes for NiMH and NiCd batteries (not naming Li-Po mode) and I plan to:
  • Discharge the battery. (already done)
  • Switch to mode for charging NiCd batteries.
  • Set charging current to 2 A.
  • Start charging and wait until finished. :)
I am not sure whether NiCd mode is more suitable than NiMH mode for the task. Or should I forget the entire idea of using such a charger?
You might be able to use the NiCd charger to put charging current into the battery. It's the part where you "wait until finished" that the problem arises. The charge termination schemes (when to automatically stop charging) will be different. For lead-acid, probably switching from current-limit mode to voltage-limit mode at some maximum safe charging voltage. For NiCd/NiMH, watching the voltage for where it goes "over the hill" from increasing to decreasing, and/or the temperature rises quickly. Plus some other safety features, such as timeout, over/under-voltage, over/under-temperature, etc.
If you put the wrong chemistry on the charger it may never see what it's looking for to cease charging, because the battery behaves differently (voltage graphed over time has a different pattern). It could keep charging literally until the battery explodes. If you understand what the battery requires, and what the charger does, you might be able to use it anyway, to the extent you can manually observe and terminate charging as appropriate. You're risking destroying the battery, but in some cases getting a partial charge right now is more valuable than a longer lifespan later.
Your stated goal is measuring the capacity of the battery, rather than, say, getting enough charge back into your car battery so you can start the car and drive it around to finish recharging. If all you wanted to do was get "some" charge into the battery, considering you already know it's discharged, you could probably let it charge from your 2A source for "a while" and disconnect it manually after some time considerably less than (64A-hr/2A)=32hr, say 8-12 hours, watching with a voltmeter that the voltage doesn't exceed the maximum safe voltage and disconnecting early if it does. For your purposes of getting the battery fully charged and discharging to measure capacity, you'd want a proper charge termination scheme, which you don't have.
  • \$\begingroup\$ A helpful answer with several inspirative points, thank you Matt. \$\endgroup\$
    – miroxlav
    Apr 23, 2014 at 3:09
No.
The technique for charging lead-acid is entirely different from NiCd or NiMH.
See http://pdf.wholesalesolar.com/battery-folder/charging_instruction_2011_2.pdf and http://www.jaycar.co.nz/images_uploaded/nicads.pdf for an idea of the differences.
So, no.
The charger you linked to is capable of charging LiPo cells. The charging profile for LiPos is very similar to that for lead acid batteries with the exception of the charge termination and finished voltage levels.
If you set your charger to 3 cell LiPo the termination voltage will be 4.2 x 3 = 12.6V. Cutting the charge at this voltage will be too early to achieve full capacity. 13.8V would probably be ideal. Anyhow you will have a limited risk of overcharging with the LiPo setup.
Some links that might be of use: http://batteryuniversity.com/learn/article/charging_the_lead_acid_battery http://batteryuniversity.com/learn/article/how_to_measure_state_of_charge
  • \$\begingroup\$ Thank you for idea based on outside-the-box thinking. I got the point. \$\endgroup\$
    – miroxlav
    Apr 23, 2014 at 3:11
