1- DC12V Coil Power Relay 10A DPDT LY2NJ HH62P HHC68A-2Z With Socket Base
2- Amico 12V DC Coil Power Relay DPDT LY2NJ HH62P-L JQX-13F 10A With PTF08A Socket Base
First assumption is that they are the same thing, but before I jumped to a conclusion I wanted to get some clarification.
If these are different what makes them different?
Thanks in advance!
The picture there doesn't show it very clearly at all, but the "-L" suffix specifies that there should be an LED indicator on the coil contacts to indicate relay activation.
  • \$\begingroup\$ Is that the only difference between the two? \$\endgroup\$
    – Adjit
    Apr 21, 2014 at 23:08
  • \$\begingroup\$ Based on the product descriptions and the datasheet, yes. \$\endgroup\$ Apr 21, 2014 at 23:09
  • \$\begingroup\$ Okay. I guess I was getting confused by the base product numbers, two different manufacturers. Awesome, thanks. I was trying to find the product sheet for the amazon one but couldn't seem to find it. \$\endgroup\$
    – Adjit
    Apr 21, 2014 at 23:11
  • \$\begingroup\$ Most Chinese "knock-offs" don't have a datasheet anywhere, but they're usually reasonably adherent to the originals. \$\endgroup\$ Apr 21, 2014 at 23:11
  • \$\begingroup\$ So if you were picking one, disregarding price which would you choose? \$\endgroup\$
    – Adjit
    Apr 21, 2014 at 23:12
