I'm using a ATtiny84 and with three 74HCT595 serial to parallel converters to drive 24 LEDs. Every thing works fine, but when I try to light up more than 10 LEDs at the same time, the ATtiny84 program resets. I'm thinking a dip in voltage related to high load it causing this.
I've tried running it via a iPhone charger, PC USB but still the same issue. If I use the Arduino Uno to drive the LED's instead of the ATtiny84 it all works fine.
Any ideas on how to get around this? Do I need to add a capacitor somewhere or do I have to switch off some brown out voltage thing in the ATtiny?
Update:
I'm trying to make a clock. Two rings of 12 LEDs. The three 74HCT595 are chained using the overflow pin connected to the input of the next one. The 74HCT595 has 8 outputs so I need 3 of them for 24 LED's. The 3 digital pins of the ATtiny84 is used for clock, input and rclk.
Code: https://gist.github.com/anonymous/be75cd17bd5773f0df88
