There are a number of style issues here and one major problem.
Fru1tbat has pointed out that you never initialise MainCounter : one way to do so would be to drive the Reset input with a simple waveform :
RESET <= '0', '1' after 100 ns, '0' after 200 ns;
in the parallel execution region (after the architecture "begin") would do so. Note that this is for simulation only, and it would be MUCH better to make RESET an input port and drive it from your simulation testbench.
Secondly (and this is the major problem, waiting to bite you randomly in real hardware) the RESET clause in process COUNT should be simplified to ONLY clear MainCounter
on reset. Then the wrapround clear should be moved into the clocked part of the process:
if Reset = '1' then
MainCounter <= (others => '0');
elsif rising_edge(Clk) then
if MainCounter >= 12345 then
else
MainCounter <= MainCounter + 1;
end if;
end if;
The reason for this is subtle if you're not used to hardware design : as expressed, you have a pile of asynchronous logic waiting to clear the counter if it momentarily transitions to a high number while counting. So counting from X"7FFF" to X"8000" it will probably momentarily pass through X"FFFF" ... and reset itself.
By moving that logic to the clocked part, it will only reset if the temporary state persists until the next clock edge : and the timing analysis tools will report timing failure if that is even a possibility.
Now the warnings : Metavalues at 0 ns are basically harmless. Metavalues persisting AFTER reset is complete are a different matter...
And the style issues :
You can compare Unsigned against simple integer literals (because numeric_std overloads comparison operators with mixed operand types) and that would make the code MUCH more readable. Better : use constant declarations instead of magic numbers. (As you discovered, you can't assign an integer literal to an unsigned; because assignment is not an operator. There are to_unsigned and to_integer conversion functions for that purpose)
There is no need for parentheses around boolean expressions e.g. in if-statements. Some C programmers use them out of habit, but it looks needlessly cluttered to me.
Your SLOW process is unclocked, despite the clock in its sensitivity list... I prefer simple clocked processes; they avoid the problems that plague combinational processes such as SLOW - which will not work correctly unless you add all the RHS signals (here - only Maincounter) to the sensitivity list.
