I can't get my copy of cad eagle to create tag type of label for a wire or a net. Instead I get simple text type of label. GND label is what I am trying to get.
I have tried turning xref on and off, and changing size or font. In the end, all I get is simple plain text label. So, how do I get the fancy tag type of label?
  • \$\begingroup\$ See this answer. \$\endgroup\$
    – David
    Commented Apr 30, 2014 at 17:50
  • \$\begingroup\$ @David That is exactly what I am doing. I have selected the pretty arrow, same size, ratio, and font, yet I get simple text label. \$\endgroup\$
    – jM2.me
    Commented Apr 30, 2014 at 17:56
  • \$\begingroup\$ Then you are either doing it wrong or you've found a bug. Ensure you are choosing the options from the linked post. If you are, record your steps (video or screenshots) and report it to Cadsoft. \$\endgroup\$
    – David
    Commented Apr 30, 2014 at 17:58
  • \$\begingroup\$ youtube.com/watch?v=zMHEg9M8FWA Then I suppose it is a bug or an issue with my installation of software. \$\endgroup\$
    – jM2.me
    Commented Apr 30, 2014 at 18:11
  • \$\begingroup\$ Yes - looks like it to me. Report it to Cadsoft. \$\endgroup\$
    – David
    Commented Apr 30, 2014 at 18:53
You can make it as a component with the value inside the tag box.
What about this?
But remember that if you want to have similar pins (on the same net) connected, you must use the Name command for every particular net segment! Placing this component on a wire doesn't tell EAGLE to connect those wires!
  • \$\begingroup\$ Is there a way to bind this nice tag component with default label command? For example, below is link to video showing just that. youtu.be/6ikZHzEYQcQ?t=24s \$\endgroup\$
    – jM2.me
    Commented Apr 30, 2014 at 17:51
  • \$\begingroup\$ Well actually that is the correct way of doing it. I didn't know of that feature of EAGLE. \$\endgroup\$
    – Cornelius
    Commented Apr 30, 2014 at 17:53
  • \$\begingroup\$ Yes, but that feature does not seem to work for me. I pointed this out on comment to the question, I have tried adding the label with exactly same options selected. As a result, it ends up being simple text label nonetheless. \$\endgroup\$
    – jM2.me
  • \$\begingroup\$ This requires a footprint right? A device needs a symbol and a footprint. Nets have names and not values. So I am totally confused with your approach. Can you please elaborate? \$\endgroup\$
    – netskink
    Commented Feb 6, 2021 at 22:00
