I've coded this state in VHDL, but I am having problem getting into a certain state.
    architecture Behavioral of game is
type LIST  is ARRAY (11 downto 0) of std_logic_vector(3 downto 0);
Constant LISTEN: LIST := ("0010","0100","1000","0001","0100","0010","0010","0010","1000","0001","0010","0001");
begin
process(CLK)
variable prescaler: integer range 0 to 50000000;
Variable control: std_logic := '0';
variable pointer: integer range 0 to 11:=0;
variable test: std_logic:='0';
variable error: std_logic:='0';
variable top_pointer: integer range 0 to 11 := 0;
variable buttontimer:  integer range 0 to 50000000 := 0;
begin
if rising_edge (clk) then
            if control = '0' and error = '0' then
                winLEd <= "01";
                    if(prescaler < 49999999/1) then
                        prescaler := prescaler + 1;
                    else
                        prescaler := 0;
                        top_pointer := top_pointer + 1;  -- Top pointer increment
                        control := '1'; --- trigger event to get to new state
                        --test := '0';
                    end if;
            end if;
                    if control = '1'  and error = '0' then
                        winLEd <= "11";
                    --  test := '0';
                        if pointer > (top_pointer) then     -- If pointer is higher than toppointer, it means the sequence has to be incrementet.
                                LED <= "0000";
                                control := '0';
                                pointer := 0;
                                test := '0';
                                error:= '0';
                        end if;
                        --if switch = "0000" then
                                if switch = LISTEN(pointer-1) and pointer<= top_pointer  then -- Checks if the switch match the sequence.
                                    test := '1';
                                    buttontimer := buttontimer + 1;
                                    errorLed <= "01";
                                        if switch = "0000" and test = '1' and buttontimer < 49999999/1 then
                                            pointer:= pointer +1;
                                            test := '0';
                                            errorLed <= "10";
                                            buttontimer:= 0;
                                        end if;
                                end if;
                                if switch /= LISTEN(pointer-1) and switch /= "0000"  then  -- if it doesn not match, error will be set high => trigger an new state.
                                    error:= '1';
                                end if;
                                        Led <= LISTEN(pointer-1);
                                          errorLed <= "11";
                                            error:= '0';
                                            control := '1';
                                        end if;
                        --end if;
                    end if;
                    if error = '1' then  -- stays here infinetly until board is reset.
                                winLED <=  "10";
                                errorLed <= "00";
                                Led <= switch;
                    end if;
end if;
end process;
end Behavioral;
I am having problem incrementing pointer here. Listen is an array, containing different 4 bit patterns. The Switch is the switches on my FGPA, I've used errorLED to see where I am in code, I see that I am entering this if statement, when the switches mathes the 4 bit pattern.
  • \$\begingroup\$ Does it work in simulation? \$\endgroup\$ May 6, 2014 at 10:02
test only is 1 when this code is entered:
if switch = LISTEN(pointer-1) and pointer<= top_pointer and test = '0' then --  Checks if the switch match the sequence.
  test := '1';
  errorLed <= "01";
end if;
In this if statement, switch has a value of LISTEN(pointer-1). Then further down in the same process, switch needs to be "0000" and test = '1' in order to hit this code.
if switch = "0000" and test = '1' and buttontimer > 1  then
  test := '0';
  errorLed <= "10";
  buttontimer:= 0;
end if;
So, the above code is only going to be entered when switch = LISTEN(pointer-1) = "0000", and buttontimer needs to meet it's requirement too, and pointer needs to hit it's requirement too (so that test can be 1).
Another note is that since you reset the value of test to 0 at the beginning of the clock cycle, that the value of test isn't going to carry over from one clock cycle to the next.
  winLEd <= "11";
  test := '0'; << remove this line
end if;
EDIT: In order to remember test, in the first block of code, remove the test := '0' at the beginning. You are already setting test to zero when the switch is de-asserted.
The FPGA is operating a lot faster than your finger can move. it's going to have run lots of clock cycles between you asserting the switch and de-asserting it. for that reason, you're going to need to remember the value of test, so that when the switch is de-asserted, the FPGA will remember that the switch was pressed. This is why I'm suggesting the removal of the test := '0'.
  • \$\begingroup\$ So you want me to insert it inside first if statement?? \$\endgroup\$ May 3, 2014 at 14:43
  • \$\begingroup\$ Please look at my edit \$\endgroup\$ May 3, 2014 at 14:46
  • \$\begingroup\$ what do you want to achieve? \$\endgroup\$
    – stanri
    May 3, 2014 at 14:59
  • \$\begingroup\$ I want to increment the pointer when what i press is equal to the pattern from the array, if not, it has to set error 1. \$\endgroup\$ May 3, 2014 at 15:09
    \$\begingroup\$ you can write a testbench which generates a test switch signal. See seas.upenn.edu/~ese171/vhdl/VHDLTestbench.pdf and vhdlguru.blogspot.com/2010/03/how-to-write-testbench.html. Since you have access to all the signals during every clock cycle, it's easier to see exactly where your code is going wrong. \$\endgroup\$
    – stanri
    May 3, 2014 at 16:55
