I have a lot of old MIDI equipment that was recently given to me by a retired music teacher. I have a lot of interest in it, and would like to make a MIDI synth. It does not need to be high quality or sample based, but I want to know how to implement a MIDI decoder in hardware.
I know that MIDI is just digital signals representing instruments, so I'm thinking something like this.
quick and simple diagram of what I want Yeah, it's not a technical diagram. But basically, I want a really excellent guide to how MIDI works. What the signal contains and so on. I have an arduino ready to act as a PWM generator, and I have tested it. It just needs to generate simple waves (like square waves, NES/Famicom style).
Does anyone know a concise, easy to understand documentation for the MIDI standard? Something like what would be in "The Art of Electronics" (the textbook) if it talked about MIDI at all. Something that a beginner could understand, preferably. I mainly work in analog technology, so this has been a new experience for me.
Thank you. (By the way, I'm not asking you to build it for me; I just want to know where a good document is. I want to do this project on my own. Nothing more complex than simple logic IC's, so don't tell me about those MIDI generating IC's.)
Start with, say, a guide to the protocol.
Given that you've decided to use an Arduino, you can just speak MIDI more or less directly. There's even a handy tutorial on the Arduino website for MIDI out! MIDI input is slightly more electrically complex as you're supposed to have an optoisolator in there to avoid ground loops.
It's almost entirely a software project, but if you're willing to pick up code from the internet should be reasonably straightforward.
Edit: a bit more googling has found someone who's actually done this, in 40xx CMOS rather than 74: http://www.pykett.org.uk/a_midi_pedalboard_encoder.htm
That's MIDI output rather than input. I still maintain there's no point doing it by halves: if you're going to do MIDI decode in hardware, do all the audio in hardware too, don't just put an Arduino in there as a PWM generator. And if you do have the Arduino, let it do the protocol bit and consider moving the audio side to analog.
  • \$\begingroup\$ Thanks. I'll try this - but I was really looking for a way to decode the MIDI with 74 series IC's. The arduino was only going to be the synth part. I suppose if I can't figure it out I will use your method. (BTW thanks for the link!) \$\endgroup\$
    – Wyatt Ward
    May 4, 2014 at 21:52
  • 4
    \$\begingroup\$ Saying "I want to decode MIDI using 7400 series ICs" is like saying "I want to make a motorcycle engine, but I really want to smelt my own ore". You are not going to be shortchanging yourself on experience if you use a microcontroller to make the interface. Wiring 7400 series ICs together to make your own UART will be more work than the actual MIDI portion of it, with no real benefit over grabbing something off the shelf. \$\endgroup\$ May 4, 2014 at 22:16
  • \$\begingroup\$ See edit: I've found a webpage for encoding MIDI without a cpu, schematics and everything. \$\endgroup\$
    – pjc50
    May 4, 2014 at 22:43
    \$\begingroup\$ As a historical note, MIDI was always meant to be encoded and decoded by a CPU, and not discrete hardware. Some of the first MIDI synthesizers all used (what were then very expensive) micro-controllers. The Prophet 600 uses a Z80, the Roland JP-6 uses a 8051. \$\endgroup\$
    – Zuofu
    May 5, 2014 at 2:44
    \$\begingroup\$ Zuofu: 3 years later coming back to this I'd agree. I eventually did use a uC to do it. My Roland MT-32 uses an intel CPU as well, an 8095 (MCS-96), btw. \$\endgroup\$
    – Wyatt Ward
    Mar 25, 2017 at 22:08
