I would like to automate a process which will require applying force to the plunger of a 5ml syringe to dispense fluid at about 10ul per second onto a 25 mm by 75mm surface and I am thinking of using an arduino to control an actuator that will apply this force to the plunger. I am not sure if this is the best way to go or the best way to go about it . Any help would be greatly appreciated!!!
The fluid dispenser I use has a pneumatically actuated syringe that uses a regulator and a flow control valve to control the rate of dispensing. There is a solenoid valve controlled by a timer and foot switch that determines the total amount dispensed. You could replace the timer with your Ard**o.
One suggested answer is pnuematics. However, if you do not have the space or money for a pnuematic set up you can also you a linear actuator, or linear servo. This would give more precise control for less money. The downside is that it would be much slower than pnuematics.
The way this is typically done is with a syringe pump - a stepper and lead-screw driving a syringe. They are very precise both in dispense volume and rate of delivery.
