I’m about to start the manual and then auto routing process of my schematic see the following link for my schematic but before doing this I’ve read quite a lot on different bits of advice on completing the schematic properly before embarking on any routing.
With regards to the routing I’ve read up on main aspects such as the selection of the routing grid in relation to the trace width, avoiding dimension errors and avoiding clearance errors.
Regarding my schematic I’ve got two components with each having a pin that I do not need to connect to anything at all. I’ve followed different pieces of advice and realized there is no “not connected” library in Eagle hence I created mine as per the following link. I then connect this custom symbol to my IC pin but no connection takes place and when I run my ERC check I come across the following errors in relation to both pins:
  • “No SUPPLY for POWER pin U1 TAB”.
  • “Unconnected INPUT pin IC1 ADJ”.
Schematic
Original image
In addition to the above problem, can anyone see any other issues with my schematic? Apart from the values of specific components which I intentionally deleted can anyone see any problem on my schematic that I might have not anticipated? Any help is appreciated.
Now moving on to the board routing (which BTW I undertook before realizing the above mentioned problem), I’ve come learn a lot in the recent days about the following things to watch out for when laying out components and subsequently undertaking the routing:
  • Selection of the routing grid (in relation to the trace width): I have a routing grid of10 mil and in the DRC sizes setting I have a minimum trace width of 10mil.
  • Selection of the trace width whilst watching out for current carrying traces.
  • Avoiding dimension errors.
  • Avoiding clearance errors.
The following link illustrates the placement of my components before I undertake manual routing and after but if need be auto routing. Just to mention in the image below I have already used the ratsnest tool
Board placement
Original image
Can anyone please identify anything at all that would cause me a problem in any way? Again any help is appreciated as it would save me time and effort solving errors.
  • \$\begingroup\$ Did you forget the ">VALUE?" text on some of your components? Also, changing the basepoint of ">NAME?" will move it to the standard spacing. \$\endgroup\$ May 6, 2014 at 16:55
  • \$\begingroup\$ The positioning of R27, R43, R45, and R46 are suspect. Careful with the radiation pattern of U$2. P1 is going to be awkward if you ever want to sandwich the board between two others; I recommend moving it over near (but not too close to) S3. \$\endgroup\$ May 6, 2014 at 17:00
  • \$\begingroup\$ You don't say what U1 and IC1 are, but as long as you know what you are doing, you can just Approve the ERC errors from Eagle and ignore them for now on. BTW, you IC numbering is inconsistent, since you have format Ux, U$x, and ICx all on the same schematic. \$\endgroup\$
    – tcrosley
    May 6, 2014 at 17:07
  • \$\begingroup\$ In CAD systems I've used, ERC and DRC errors are just treated as warnings to the user, and do not prevent the program from creating the PCB or board manufacturing files. ERC and DRC errors can be ignored, as long as you are sure that they are acceptable for your design. (It is best to minimize such errors if possible, of course.) \$\endgroup\$ May 6, 2014 at 17:27
  • \$\begingroup\$ @Ignacio: For U$2 which is the ETRX357HR Telegesis zigbee module I’ll be using the following antennae. I’ve moved the suspect looking resistors (R27, R43, R45, and R46) inwards and I guess u mentioned this in order to avoid dimension problems. As for the standard spacing of the values and names I’ll correctly rename everything. I’ve also moved P1 which is my programming header. \$\endgroup\$
    – user34395
    May 7, 2014 at 9:56
U$1 has a TAB on that back that is probably a heatsink. Check to see if it is ground-connected, high-voltage, or floating. I'm assuming its your voltage regulator. Make a big polygon pour around this tab for heat sinking. From experience, these can heat up a lot. The warning EAGLE is telling you is that the IC symbol is listed as a power input and wants either a ground symbol or a power symbol to be connected to this pin. It appears to be floating in your schematic. If the TAB is internally connected to ground, then add a connection to the ground pin and the warning will go away.
Generally, its always a good idea to stick a wire on an IC pin, give it a name, and then connect it to a test pin that you can put on your board later for debugging. This can greatly help you down the road and also make your unconnected warnings go away.
  • \$\begingroup\$ For U1 which indeed is a LDO 3.3v voltage regulator – seeww1.microchip.com/downloads/en/DeviceDoc/22049e.pdf in its datasheet i.e. as per diagrams on page 2 or page 11, I can’t seem to identify if the tab is internally connected to ground. For your information I’m using the SOT-223-3 package \$\endgroup\$
    – user34395
    May 7, 2014 at 10:01
