I am currently trying to get spi communication up and running between a stm32l-discovery board (uses STM32L152RCT6 mcu) and a nRF24L01 module. I have the module connected to the discovery board via the following pins (apart from the 3v and gnd):
// CS  = PB12 (SPI_NSS)
// SCK = PB13 (SPI_SCK)
// MI  = PB14 (SPI_MISO)
// MO  = PB15 (SPI_MOSI)
// CE  = PD2
My uart gives the following output:
nrf radio example
set 1500us timeout: (LOW)
It is currently stuck there because the spi registers don't seem to update and I'm not sure if I configured something wrong. My biggest problem though is that I'm not sure how I can debug this further? I'm still very new to stm32.
Here is my current code:
#include "stm32l1xx_conf.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdarg.h>
/* Memory Map */
#define CONFIG 0x00
#define EN_AA 0x01
#define EN_RXADDR 0x02
#define SETUP_AW 0x03
#define SETUP_RETR 0x04
#define RF_CH 0x05
#define RF_SETUP 0x06
#define STATUS 0x07
#define OBSERVE_TX 0x08
#define CD 0x09
#define RX_ADDR_P0 0x0A
#define RX_ADDR_P1 0x0B
#define RX_ADDR_P2 0x0C
#define RX_ADDR_P3 0x0D
#define RX_ADDR_P4 0x0E
#define RX_ADDR_P5 0x0F
#define TX_ADDR 0x10
#define RX_PW_P0 0x11
#define RX_PW_P1 0x12
#define RX_PW_P2 0x13
#define RX_PW_P3 0x14
#define RX_PW_P4 0x15
#define RX_PW_P5 0x16
#define FIFO_STATUS 0x17
#define DYNPD 0x1C
#define FEATURE 0x1D
/* Bit Mnemonics */
#define MASK_RX_DR 6
#define MASK_TX_DS 5
#define MASK_MAX_RT 4
#define EN_CRC 3
#define CRCO 2
#define PWR_UP 1
#define PRIM_RX 0
#define ENAA_P5 5
#define ENAA_P4 4
#define ENAA_P3 3
#define ENAA_P2 2
#define ENAA_P1 1
#define ENAA_P0 0
#define ERX_P5 5
#define ERX_P4 4
#define ERX_P3 3
#define ERX_P2 2
#define ERX_P1 1
#define ERX_P0 0
#define AW 0
#define ARD 4
#define ARC 0
#define PLL_LOCK 4
#define RF_DR 3
#define RF_PWR 6
#define RX_DR 6
#define TX_DS 5
#define MAX_RT 4
#define RX_P_NO 1
#define TX_FULL 0
#define PLOS_CNT 4
#define ARC_CNT 0
#define TX_REUSE 6
#define FIFO_FULL 5
#define TX_EMPTY 4
#define RX_FULL 1
#define RX_EMPTY 0
#define DPL_P5 5
#define DPL_P4 4
#define DPL_P3 3
#define DPL_P2 2
#define DPL_P1 1
#define DPL_P0 0
#define EN_DPL 2
#define EN_ACK_PAY 1
#define EN_DYN_ACK 0
/* Instruction Mnemonics */
#define R_REGISTER 0x00
#define W_REGISTER 0x20
#define REGISTER_MASK 0x1F
#define ACTIVATE 0x50
#define R_RX_PL_WID 0x60
#define R_RX_PAYLOAD 0x61
#define W_TX_PAYLOAD 0xA0
#define W_ACK_PAYLOAD 0xA8
#define FLUSH_TX 0xE1
#define FLUSH_RX 0xE2
#define REUSE_TX_PL 0xE3
#define NOP 0xFF
/* Non-P omissions */
#define LNA_HCURR 0
/* P model memory Map */
#define RPD 0x09
/* P model bit Mnemonics */
#define RF_DR_LOW 5
#define RF_DR_HIGH 3
#define RF_PWR_LOW 1
#define RF_PWR_HIGH 2
#define SPI_CS_HIGH GPIO_WriteBit(GPIOB, GPIO_Pin_12, Bit_SET);
#define SPI_CS_LOW GPIO_WriteBit(GPIOB, GPIO_Pin_12, Bit_RESET);
#define NRF_CE_HIGH GPIO_WriteBit(GPIOD, GPIO_Pin_2, Bit_SET);
#define NRF_CE_LOW GPIO_WriteBit(GPIOD, GPIO_Pin_2, Bit_RESET);
void usart_write(uint8_t ch)
      USART_SendData(USART1, (uint8_t) ch);
      while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
void usart_print( char *msg )
    int len = strlen( msg );
    for ( int c = 0; c < len; c++ )
        usart_write( (uint8_t)*msg++ );
void delay( int a )
    volatile int i, j;
    for ( i = 0; i < a; i++ )
        j++;
uint16_t spi_transfer( uint16_t data )
    while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
    usart_print( "(senddata)" );
    SPI_I2S_SendData( SPI2, data );
    usart_print( "(wait)" );
    // wait for transfer to finish
    while (SPI_I2S_GetFlagStatus( SPI2, SPI_I2S_FLAG_RXNE ) == RESET);
    usart_print( "(recvdata)" );
    return SPI_I2S_ReceiveData(SPI2);
void spi_send( uint16_t data )
    while ( SPI_I2S_GetFlagStatus( SPI2, SPI_I2S_FLAG_TXE ) == RESET );
uint16_t spi_read(void)
    while ( SPI_I2S_GetFlagStatus( SPI2, SPI_I2S_FLAG_RXNE ) == RESET );
uint16_t write_register_data(uint8_t reg, const uint8_t* buff, uint8_t len )
    uint16_t status;
    SPI_CS_LOW;
    status = spi_transfer( W_REGISTER | ( REGISTER_MASK & reg ) );
    while ( len-- )
        spi_transfer(*buff++);
    SPI_CS_HIGH;
    return status;
uint16_t read_register_data(uint8_t reg, uint8_t* buff, uint8_t len )
    uint16_t status;
    SPI_CS_LOW;
    while ( len-- )
        *buff++ = spi_transfer(0xff);
    SPI_CS_HIGH;
    return status;
uint16_t write_register_value(uint8_t reg, uint8_t value)
    uint16_t status;
    usart_print( "(LOW)");
    SPI_CS_LOW;
    status = spi_transfer(W_REGISTER | ( REGISTER_MASK & reg ) );
    spi_transfer( value );
    usart_print( "(HIGH)");
    SPI_CS_HIGH;
    return status;
uint16_t read_register_value(uint8_t reg)
    uint16_t status;
    SPI_CS_LOW;
    spi_transfer( 0xff );
    SPI_CS_HIGH;
    return status;
int main(void) {
        GPIO_InitTypeDef gpio_init;
        USART_InitTypeDef usart_init;
        USART_ClockInitTypeDef usart_clk_init;
        SPI_InitTypeDef spi_init;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB | RCC_AHBPeriph_GPIOD, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
        // spi
        // CE  = PD2
        gpio_init.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
        gpio_init.GPIO_Mode = GPIO_Mode_AF;
        gpio_init.GPIO_Speed = GPIO_Speed_40MHz;
        gpio_init.GPIO_OType = GPIO_OType_PP;
        gpio_init.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOB, &gpio_init);
        gpio_init.GPIO_Pin = GPIO_Pin_12;
        gpio_init.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_PinAFConfig( GPIOB, GPIO_PinSource13, GPIO_AF_SPI2 );
        GPIO_PinAFConfig( GPIOB, GPIO_PinSource14, GPIO_AF_SPI2 );
        GPIO_PinAFConfig( GPIOB, GPIO_PinSource15, GPIO_AF_SPI2 );
        gpio_init.GPIO_Pin = GPIO_Pin_2;
        gpio_init.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOD, &gpio_init);
        SPI_StructInit(&spi_init);
        spi_init.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        spi_init.SPI_Mode = SPI_Mode_Master;
        spi_init.SPI_DataSize = SPI_DataSize_8b;
        spi_init.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
        spi_init.SPI_NSS = SPI_NSS_Soft;
        spi_init.SPI_CPOL = SPI_CPOL_Low;
        spi_init.SPI_CPHA = SPI_CPHA_1Edge;
        spi_init.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_Init(SPI2, &spi_init);
        SPI_Cmd(SPI2, ENABLE);
        SPI_CS_HIGH;
        NRF_CE_LOW;
        // uart
        // PA9 = Tx, PA10 = Rx
        gpio_init.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10;
        GPIO_Init(GPIOA, &gpio_init);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
        USART_ClockStructInit(&usart_clk_init);
        USART_ClockInit(USART1, &usart_clk_init);
        usart_init.USART_BaudRate =            9600;
        usart_init.USART_WordLength =          USART_WordLength_8b;
        usart_init.USART_StopBits =            USART_StopBits_1;
        usart_init.USART_Parity =              USART_Parity_No ;
        usart_init.USART_Mode =                USART_Mode_Rx | USART_Mode_Tx;
        usart_init.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_Init(USART1, &usart_init);
        USART_Cmd(USART1,ENABLE);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET) {}
        usart_print( "nrf radio test\r\n" );
        delay(50000);
        usart_print( "set 1500us timeout: " );
        uint16_t status = write_register_value(SETUP_RETR,(4 << ARD) | (15 << ARC));
        usart_write( status ); usart_print( "\r\n" );
        usart_print( "begin\r\n" );
        while (1) {
        return 0;
    \$\begingroup\$ dangerousprototypes.com/2012/02/12/… \$\endgroup\$ – RedGrittyBrick May 7 '14 at 10:33
    \$\begingroup\$ Have you verified that the SPI signals look correct using an oscilloscope? \$\endgroup\$ – Joe Hass May 7 '14 at 11:26
  • \$\begingroup\$ No I have not since I don't have a oscilloscope handy, but @RedGrittyBrick, I do have an old buspirate handy so I'll give that a try. \$\endgroup\$ – Tom Van den Bon May 7 '14 at 18:06
  • \$\begingroup\$ @TomVandenBon BusPirate is better than nothing, but not as good as seeing the signal. \$\endgroup\$ – Scott Seidman Jun 2 '15 at 21:42
Just one little thing I've noticed in the first line of your "spi_transfer" function...
You seem to be waiting on an SPI1 flag when you're using SPI2?
| improve this answer | |
My bet is that your problem are those usart_print intermingled with the SPI transfer. With typical settings usart is at least 10 times slower then SPI and the SPI has no FIFO. So what probably happens is that by the time usart_print finishes all that data is gone - you did not read it on time.
For comparison here is my working code for SPI transfer on STM32L152:
    //CS low
    GPIOA->BRR |= GPIO_Pin_4;
    for(int i = 0; i < size + 1; ++i)
        SPI_I2S_SendData(SPI1, SX1232_Buffer[i]);
        while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
        buffer = SPI_I2S_ReceiveData(SPI1);
    //CS high
    GPIOA->BSRR |= GPIO_Pin_4;
tl;dr Comment out those usart_print statements from spi_transfer and see if it helps.
