I am using the BMI055 on my AVR through I2C.
Datasheet: http://ae-bst.resource.bosch.com/media/products/dokumente/bmi055/BST-BMI055-DS000-06.pdf
I set it to filtered output at an ODR of 1000Hz and I poll it every 1005us.
I set it to 1000deg/s sensitivity, at 16 bit output. That gives 32.8 LSB/degree
I am reading the values from the FIFO in bypass mode.
Now for testing I have a function which does the following(pseudo):
dt = microseconds passed since last call (around 1000)
scale = 1/32.8/1000000;
deltaANGLE[axis] = dt * scale;
static sum[axis] += deltaANGLE[axis];
Every 1000 calls:
print the sums[] to serial;
sum[axis]=0;
I would have expected a bit noise and drift during 1 second (1000 samples) but I get an offset value from -3 to -11 on all 3 axis when having it on the still table.
Also the values change so much, even an average correction would not help much
Time dif 995 us
Angles: -9.944047 -9.904691 -10.001564
Time dif 1003 us
Angles: -9.846170 -9.824638 -9.923825
Time dif 998 us
Angles: -5.871545 -5.805600 -5.935478
Time dif 1005 us
Angles: -8.871223 -9.628742 -8.884630
Time dif 1009 us
Angles: -8.874594 -8.875291 -8.956609
Time dif 1007 us
Angles: -5.902205 -5.916657 -5.970954
It also puzzled me that the three axes show the same strange offset always.
When moving the board within the integration second it shows 'about' the right change (=-15 deg from the expected value)
I think I do something wrong but I can not find the problem.
Addon1: I just found that increasing the time of my polling routine significantly reduces the error. I have the ODR set at 1000Hz, if I pull at 500Hz I get low noise and a quite accurate result. Although it should mean the sensor is 50% of the time saturated and waits for my poll ? can such noise be the result of an issue between my polling and the sensors bandwidth/ODR setting ?
Addon2: Another several hours wasted. I experimented with various settings regarding poll rate and sensor ODR/bandwidth.
When polling faster than ODR I get completely crazy values from the FIFO, datasheet said it should give ZERO values..
The new data interrupt (in 8th byte of FIFO) is permanently set to 1 wth rare outages to 0, even if I poll 3 times faster than sampling rate .
When polling slower than the sampling rate I get better values but the Y angle sporadically jumps on -3 degree every few seconds (still accumulating, now 2 seconds).
The Z axis is quite stable, after a few minutes total accumulation it shows 7 degree offset.
The X axis shows around 36.
The Y axis -133 degree.
I can not think about a way to compensate such sudden spikes, it is not a general offset. My current conclusion is that the chip itself is bad.(?)
Update with real code: Initialization:
data[0]=0x0F;data[1]=0b000; //001 = 1000deg/sec,000 =2000
error += twiSend( ACC_BM055_ADDR_GYRO, data, 2 );
_delay_us(5);
data[0]=0x10;data[1]=0b0011; // 0011 = 400hz odr 2khz = 0001. decimation factor 2, odr 1000hz (1k=0b0010)
_delay_us(5);
data[0]=0x13;data[1]=0b0; // filter 1, shadow 1
_delay_us(5);
data[0]=0x15;data[1]=0b0; // all interrupts off
_delay_us(5);
_delay_us(5);
data[0]=0x3E;data[1]=0b00; // FIFO bypass und XYZ modus
_delay_us(5);
data[0]=0x31;data[1]=0b11101111; // try to run offset comp
_delay_ms(1300);
data[0]=0x15;data[1]=0b10000010; // auto offset .. doesnt help
_delay_us(5);
data[0]=0x00;
error += twiSend( ACC_BM055_ADDR_GYRO, data, 1 );
error += twiReceive( ACC_BM055_ADDR_GYRO, result, 1 );
if (result[0] != 0b00001111) error+=32;
if (error == 100) error=0;
return error;
I am polling the FIFO buffer for 6 bytes (burst read from address 0x3F) using a timer which hits every n microseconds.
As soon as I have received the 6 bytes this happens:
uint8_t axis;
float scale, deltaGyroAngle[3];
static uint16_t time_last;
uint16_t time_now = get_micros();
scale = (time_now - time_last) * GYRO_TO_RAD_FACTOR; // gyro * dt
for (axis = 0; axis < 3; axis++)
deltaGyroAngle[axis] = attitude.gyro_raw[axis] * scale;
static float sum[3];
static uint16_t counter;
sum[0] += deltaGyroAngle[0];
sum[1] += deltaGyroAngle[1];
sum[2] += deltaGyroAngle[2];
if (counter++==1000) // at current 400hz it hits once per 2.5 sec, at 1000hz it hits once per second
WRITE("\n\nTime dif %u us\n",time_now-time_last);
WRITE("\nWinkelsnapshot: %f %f %f\n",(sum[0]),(sum[1]),(sum[2]));uart_wait_rx0_empty();
// This shows that Z is stable
// X is slightly unstable
// Y has random -3.5 degree per second spikes (in 1000hz mode -7)
//sum[0]=0;
//sum[1]=0;
//sum[2]=0;
counter=0;
time_last = time_now;
Another Update, this time closer to the source:
I wrote an average routine to find a bias, I am sampling the chip each 2800 us.
The ODR is set to 400HZ so 2500 us would be the minimum rate.
The general results are very good, it shows an average offset of zero over 1000 samples.
But every 1-2 seconds I get a huge spike in one of the values, close to the maximum readout.
The sensor behaves as if it received a sudden kick within two milliseconds but it is just sitting still on the table.
Here the values in signed and unsigned 16 bit format:
Sampled 00001 -0001 00005 00001 65535 00005
Sampled 00001 00000 00002 00001 00000 00002
Sampled 00001 00001 00000 00001 00001 00000
Sampled 00001 00000 00001 00001 00000 00001
Sampled -0001 -0001 00001 65535 65535 00001
Sampled 00001 00000 00000 00001 00000 00000
Sampled 00003 00006 -0001 00003 00006 65535
Sampled 00001 00007 00000 00001 00007 00000
Sampled 00000 00004 00002 00000 00004 00002
Sampled 00003 -0001 00001 00003 65535 00001
Sampled 00003 00001 00001 00003 00001 00001
Sampled 00002 00000 00001 00002 00000 00001
Sampled 00002 -18497 -0001 00002 47039 65535 <-----
Sampled -0002 00002 -0002 65534 00002 65534
Sampled 00000 -0001 00000 00000 65535 00000
Sampled 00000 00001 00000 00000 00001 00000
Sampled 00000 00002 -0001 00000 00002 65535
Sampled 00001 00001 -0003 00001 00001 65533
Sampled 00003 -0001 -0002 00003 65535 65534
Sampled 00004 -0001 00001 00004 65535 00001
Sampled 00003 -0001 00002 00003 65535 00002
Sampled 00002 -0004 00000 00002 65532 00000
Sampled 00003 -0003 00000 00003 65533 00000
Sampled 00002 00000 00000 00002 00000 00000
Sampled 00001 00001 00001 00001 00001 00001
Sampled 00002 00000 00002 00002 00000 00002
You can see the values are really low with the excepton of a spike of -18497.
If I reduce the delay between samples these spikes become more frequent.
I actually start to believe I do everything right and Bosch has a problem with their BMI055 chip or this single chip is just crazy.
A potential solution I thought about would be to let the whole sensor algorithm lag by one frame (around 2500us) and to completely ignore a sudden 1ms spike. But it would add quite some response delay to my project. A digital lowpass filter might also do a good job with less delay but a spike from 0 to 16000 (and I have seen 32k ones too) will still have an impact on the whole readout.
I wish an expert could enlighten me
