I'm trying to figure out how to power my project using LiPo batteries and a solar charging circuit.
The project will draw up to 2A at 3.3V.
I did a search for IC LiPo charging chips that also allow a simultaneous load of 2A, and have only been able to find chips in SMT packages, such as the LTC4155 I can't find any breakout boards or shields that use chips of this caliber, and am hesitant to try and solder an SMT chip to my protoboard.
As an alternative to using a single battery with a charging circuit that allows a load to be applied simultaneously, I am now considering using 2 LiPo batteries. While one is being charged by the solar charging circuit, the other is powering the main circuit. When the battery powering the main circuit is low (say 3.4 V), it gets disconnected while the other battery (that has just been charging off the solar) is connected. The low battery then gets connected to the solar charging circuit and the cycle repeats itself.
Something like this:
Does this makes sense? Are there any pitfalls to using this approach that anyone can think of?
The circuit you show is essentially OK in general operation but has the significant disadvantage that, as described, it deep cycles both batteries and reduces batterry life, even if solar energy available > required load energy. You can largely overcome this by cycling when Vbat falls only slightly. The changeover switch can be automated using 2 x MOSFETs and a comparator.
If switched manually you will get a changeover "blip" which the 50 uF will not do a lot to limit. 50 uF will drop 1 volt in 50 microseconds at 1A so in 25 uS at 2A. Your switch would need to be "rather fast" to achieve this. The comparator plus two MOSFETs as switches solution 'fixes' this with a suitably fast changeover. However, there are potentially better ways.
If you connect the battery to the load via an on off switch and the charger to the battery directly (assuming an internal diode or equivalent) the circuit will work OK in most cases. Problems might occur if you some advanced charging system (eg MPPT of some flavours) but in most cases there should be no problem. There may be some interesting "boundary conditions" (see below).
Consider:
Assume:
  • Charger capable of > 2A - say 2.5A.
  • Battery max Icharge = 2.5A (set by desihn by charger)
  • Load = 2A.
  • Battery say 50% charged.
  • Charger capable of proper CC/CV LiPo charging with Vmax = say 4.2V and tail to say 20% of Imax = 20% x 2.5A = 500 mA.
  • The solar charger should be able to charge a worst case discharged battery safely - but that is really outside the scope of the question.
Charger sees load of semi-charged-battery + 2.5A = > 2.5A. Charger "does what it can" and supplies 2.5A.
Battery charges in CC mode at 2.5-5 = 0.5A.
System voltage = battery voltage will rise as battery charges.
When /if battery reaches max voltage (ie Vbattery = say 4.2V) it will revert to CV tail (4.2V)
Boundary condition: As mentioned above, the presence of the load current hides the battery "tail current" state from the charger. As follows:
Charger now sees 2A load current + battery CV tail current.
As the load current swamps the battery tail current the charger will never "trip" the battery charging and charging will continue indefinitely as long as battery tail current + load current > 500 mA. If you charged the battery "all day long, everyday" in this mode and I load always > 500 mA then the battery would get damaged. But if load is occasionally removed or reduced to<< 500 mA the charger will trip off.
How much this matters depends on load and charging characteristics and a look at the typical load vs time situations will allow you to assess what should be done.
There are various "work arounds". One easy one is to stop charging at Vmax with bo CV current tail. This reduces available battery capacity t about 80%-90% of what you'd otherwise get - and usefully extends battery cycle life.
The switch changeover system is not without its bad effects on the batteries.
If you discharge to say 3.3V you are effectively doing multiple deep discharge cycles and battery cycle life will be low.
If Iload < Icharger_available then you COULD run the load on the solar charger with the bttery uninvolved. However, the changeover switch system does not account for this and cycles the battery unnecessarily and reduces its life.
The following is an "idea starter" only.
When Vp[v is high enough it will supply the load directly.
If Vpv is high enough and if the battery requires charging it will also charge.
Diode D1 is shown as an 1n5819 but ideally would be a MOSFet arranged as a "zero voltage drop" diode. If panel does not provide enough power for load battery will controbute.
This circuit "needs work" but has the makings of a useful system.
| improve this answer | |
  • \$\begingroup\$ Thanks for the detailed response Russell! The load will only be applied for a few hours per day, so perhaps your idea starter will work well. I think I'm going to go forward with the switch-over circuit concept, with a DoD of 60% before switch-over occurs. That way the charger will only ever see the load of the battery it is charging, and will operate correctly. I'm weary of trying to power the load with the charger, since it is MPPT-esque. The charger I'm thinking of using is the MCP73871 \$\endgroup\$ – macdonaldtomw May 11 '14 at 23:24
