I am trying to find a path loss model for "wireless sensor network". More specifically, I am looking for model for Cellular tower 100~1000MHz) and (60~600W) as transmitter and a small wireless sensor node as the receiver(most likely to be placed on ground level).
Then I come across on a model which is only applicable to "
The resulting path loss model applies to base antenna heights from 10 to 80 m, base-to-terminal distances from 0.1 to 8 km, and three distinct terrain categories. "
My question is: what is the base antenna? (Does it mean the transmitter base station antenna only or also the receiver antenna as well? Do you guys think this model will satisfy the aforemention requirement?
